Old 03-17-2002, 12:35 PM
electroluky electroluky is offline
Default G4 733 / OS 9.2.1 startup problems!!!!!!!
I just bought a G4 733 last week and put protools on it - now when I startup G4 it takes quite a long time till desktop comes up ( lot more than with my G3 before!!!!)
does anybody knows why?
please help!
thx [img]images/icons/cool.gif[/img] [img]images/icons/shocked.gif[/img]
Old 03-17-2002, 09:41 PM
Kurtstudio Kurtstudio is offline
Default Re: G4 733 / OS 9.2.1 startup problems!!!!!!!
what kind of pro\Tool extention setup did you do. There are lots of extention you don't need and some you must have removed before it will run faster.Do you have Nortons, or virus software running in background? lots of questions about you set up will be needed to answer you problems! [img]images/icons/wink.gif[/img]
Later, Kurt
Kurtstudio@mac.com
Intel duel Quad core
PT 8.0cs3
HD4
D Command / D control
Old 03-18-2002, 01:40 AM
I have norton but filesaver isn`t active - I have all extensions on (standard config 9.2.1.)
could you tell me which extensions I don`t need for PT??(had a list for 8.6....does it work for 9.2.1.??)
thx!!!! [img]images/icons/shocked.gif[/img] [img]images/icons/confused.gif[/img]
Old 03-18-2002, 01:41 AM
...no virus software
forgot that one...
Old 03-18-2002, 03:52 AM
blanos112 blanos112 is offline
Hi!
What time of the boot up process does your mac "spend more time"?
e.g. in the white startup screen?in the smiley face screen?in the welcome to macOS screen?
dimitris
Old 03-18-2002, 08:55 AM
desktop is there but control panel doesn`t appear... after 1 minute it appears [img]images/icons/confused.gif[/img] [img]images/icons/confused.gif[/img] [img]images/icons/confused.gif[/img]
why??? never had that before...
Old 03-18-2002, 09:18 AM
lagasus lagasus is offline
Try turning AppleTalk off from the chooser.
Old 03-18-2002, 09:41 AM
Pietari Koskinen Pietari Koskinen is offline
I've had this, too. Turning off the Apple Enet extension fixed my problem.
Old 03-18-2002, 11:33 AM
letrev's Avatar
letrev letrev is offline
You may need to reset the startup drive. Open the startup drive control panel and select the drive the contains your system folder.
Also try rebuilding the desktop (hold Command and Option keys while restarting).
Steven Vertel
Mixing / Mastering Engineer
High Rock Records & Studio
NYC
http://highrockrecords.com
Old 03-18-2002, 02:58 PM
vze24x2x vze24x2x is offline
It's because you have a much bigger start-up drive than you did with your older machine. I had the same concern when I had my 40gb start-up drive go bad & bought a new 80gb drive. I't'll take even more time when you start up with a new external Drive on the SCSI bus.
PT 8 startup problems fransmo Pro Tools M-Powered (Mac) 1 11-12-2009 04:04 PM
Problems on startup Spydogen 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 0 03-20-2007 02:14 PM
StartUp Problems MusSickIzLife 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 5 01-27-2004 09:02 PM
002 startup problems svenu 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 10-21-2002 11:05 AM
startup problems dans 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 12-06-1999 08:39 AM
