Old 01-10-2005, 02:25 PM
Alhuero Alhuero is offline
Default Using Both S/PDIF and ADAT with 002R - Clock ?
If I'm connecting two external digital sources to the 002R (an RCA S/PDIF input and Toslink ADAT input), can I select either input as the external source or does it have to be the ADAT input? And if I select the S/PDIF input as the clock source, does this signal then get transferred out with the ADAT output so I can effectively synch all three devices to the clock signal from the S/PDIF?
Old 01-10-2005, 02:56 PM
Mikeren Mikeren is offline
Default Re: Using Both S/PDIF and ADAT with 002R - Clock ?
Yes.
One master clock only, your choice.
Everything else slaves to it.
S/PDIF device internal --PT external (S/PDIF input). ADAT external (PT), etc...
MR
Learn to listen. Listen to learn.
Old 01-10-2005, 06:47 PM
Thanks!
S/PDIF, ADAT, Word Clock - Recording At Optical IN (003R). epu 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 02-13-2010 07:39 PM
Can't clock adat converters to 002r JimmyTambourines 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 7 01-16-2009 09:01 AM
Recording S/PDIF inputs w/ ADAT clock source on LT LE somberberry 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 01-27-2008 08:11 PM
002R ADAT clock issues... cwhite771 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 6 08-19-2007 03:38 PM
002R S/PDIF and ADAT Question spicyitaliano 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 4 05-09-2004 03:56 PM
