opening older versions of protools in v/ 6.9.2
I have files from a friend that are in a dated version of protools, but I took them assuming that the newer versions would open the older version without a problem. When I try to open the files, they seem completely unrecognizable (I get the message that there is "no application associated with the files"). When I select Pro Tools as the application to open it with, I get the message that "this is not a valid Pro Tools session".
I am positive that these are valid Pro Tools sessions as I have worked with them on my friend's mac (in their older version of Pro Tools). Any ideas how to resolve this issue? Thanks! |
Re: opening older versions of protools in v/ 6.9.2
anyone???
Are you running a Mac or PC? If you're on a PC and the files weren't setup for PC/Mac compatibility, that could be the problem. A work around might be to import the audio files into a new session.
it's going from mac to mac....and i've tried opening the files in a new session.
it's going from os9 to osX. could that be an issue? anyone from digidesign have a possible solution? |
What format are the audio files in?
....showing up as "unix executable file"s
That's very strange. I would expect all of the files in the "Audio" folder for the session to be in AIFF or WAV format.
Opening Pro Tools 9 Projects in Older Versions | br567 | macOS | 3 | 03-09-2011 09:48 AM |
Cant find older versions of protools le on avid site | TheCraftsman | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 2 | 06-11-2010 08:59 PM |
Opening older session versions in 8 | tomdiek | Pro Tools TDM Systems (Mac) | 7 | 12-30-2008 05:48 PM |
Opening HD 7.4.2 Sessions on Older Versions | Lumin | Pro Tools TDM Systems (Mac) | 2 | 10-30-2008 02:13 PM |
Opening older protools (5) session in PT7.3.1 | lordofthestrings | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 7 | 04-02-2007 02:20 PM |
