Old 04-07-2018, 09:22 PM
manfromspace manfromspace is offline
Default 2018.4 Startup Crash
Upgraded to .4 just now and I can't get protools to launch. I get the startup screen and then crash log.
I've installed via app manager and reinstalled via dmg file. Rebooted. Reset. NADA.
Any ideas?
New 2017 mbp highest specs. Latest os. Ext monitor attached. Apollo Duo w/ satellite for interface.
Old 04-08-2018, 12:31 AM
BScout BScout is offline
Default Re: 2018.4 Startup Crash
“latest os” isn’t supported (10.13.4). That may be your issue
Pro Tools Ult 2021.10, HDX 3, MTRX/SPQ, HD OmniS1 x 2, FireHD x 2, Dock, iPad Mac Pro 5,1 - 3.06 GHz 12 core - macOS 10.13.6RAM 64GB, SSD 4 x 2TB, GPU GTX 980 4GB
Old 04-08-2018, 03:00 AM
Gemylon's Avatar
Gemylon Gemylon is offline
Did you try to delete old ProTools pref. files ?
Might help you out ...
There is another thread about PT 2018.4 above this one. Try to post in there as well ...
Mac mini M1 / Pro Tools 2021.7 / MetricHalo ULN-8 / AVID Console C|24 / Universal Audio 6176 / Neumann U67 / BN Arabella / Oram S200 / UAD Octos /
Old 04-10-2018, 02:38 AM
I think it must be an os thing. 10.13.4 and 2018.4 don't seem to play well. I gave up and trashed everything and reinstalled 2018.3 and everything is working great again. I guess I'll check back from time to time and see if this ever gets ironed out...
Old 04-10-2018, 03:10 AM
There's a note in the forums somewhere from jeffro or one of the other moderators that 10.13.4 is not qualified for a reason (not that it hasn't been tested) for 2018.4. They have seen problems and so are not qualifying it.
Old 04-10-2018, 06:46 AM
Emi's Avatar
Emi Emi is offline
10.13.4 here with PT 2018.4 and runs great!
Mac Mini M1 | Mac OS Big Sur 11.6.1 | Motu 16A | Motu 828ES | Motu 1248 | Pro Tools 2021.10 Native
Old 04-10-2018, 08:00 AM
From jeffro
http://duc.avid.com/showpost.php?p=2483635&postcount=14
Old 04-10-2018, 03:12 PM
tamtamstudio tamtamstudio is offline
my tricks.
As i do every time, in case if i install some new plugins, move the most of the plugins (generally the half) in a folder on desktop and launch protools.
Leave it boot up, wait and see if it's start regularly.
Quit ProTools. Move again the plugins back in the plug-in folder and restart Protools, wait 'till the complete load and let's see if it works.
Corrado Magalotti
Tam Tam Recording studio
Old 04-10-2018, 11:42 PM
tobbelito tobbelito is offline
Same here..... crash upon startup. Trashed everything, but nothing helps.
Os 10,12,6 - Mac Mini
PT 2018,4
Reinstalled 2018,4 - but same issue
Old 04-10-2018, 11:59 PM
iLok License Manager does the same thing. Doesn't start up.... just a blue wheel comes up
https://www.dropbox.com/s/nzin8tdbpn...crash.mov?dl=0
The Ethernet port is broken as well. I'm running an Orico USB to Ethernet adapter now.
Can't log into APP Store either. Can log in at Apple.com, but not App Store
PT 2018.1 crash & fix RichrdC Pro Tools 2018 2 03-22-2018 04:21 PM
2018.3.1 crashes on startup rdpar Pro Tools 2018 9 03-21-2018 06:38 PM
Pro tools 2018.1 crashes on startup every time -- Mac 10.13.3 teego24 Pro Tools 2018 0 02-07-2018 02:33 PM
Deleting multiple instances of multichannel instrument presets causes crash in 2018.1 noiseboyuk Pro Tools 2018 4 01-29-2018 07:43 AM
PT 10.3.6 Startup Crash Greggas Pro Tools 10 17 07-28-2013 04:36 PM
