Old 04-27-2022, 01:01 PM
jplumlee jplumlee is offline
Default Pro Tools 2022.4 update is a DISASTER!
So I've had a (mostly) stable system running PT 2021.12. on a 2021 MBP M1 Max 64gb 2tb (via Rosetta 2 of course since Avid is going for dead last in Apple Silicon compatibility roll outs) Figured I'd install the update for the Clip FX alone... BIG MISTAKE. Now my virtual instruments ALL have a massive latency regardless of buffer/cache size (if they play at all). Constant freezes (that eventually wake back up) Audio drop outs. System usage is pegged at 100 PERCENT and fluctuating wildly even on modest sessions.
At first I thought maybe it was a faulty installation so I completely removed pro tools and any lingering remnants... rebooted... fresh install. SAME PROBLEMS!
So... back to 2021.12 we go. Dear Avid, you REALLY need to get your act together. There's a reason your user base is leaving en masse. I LOVE pro tools, I KNOW pro tools, I really don't want to learn something new just because Avid has decided Pro Tools isn't worthy of ACTUAL improvements...Charging us more and changing the name (yet again) is not a path to success.
This is really causing me to reevaluate my choices.
Old 04-27-2022, 01:04 PM
Default Re: Pro Tools 2022.4 Release
Old 04-27-2022, 02:53 PM
noah330 noah330 is offline
Default Re: Pro Tools 2022.4 update is a DISASTER!
No issues 9n M1 here.
Also, on both Avid.com and Sweetwater there are new packages and it looks like to keep Ultimate it’s still $399/yr if you don’t want/need the flex things.
Apple M1 Mac Studio (base model)
ProTools Carbon w/SSL XLogic MADI-AX
Instagram:
https://www.instagram.com/sparkletune/
Old 04-27-2022, 02:57 PM
jeffro's Avatar
jeffro jeffro is offline
Sorry to hear you're having trouble. If you've been through the steps for your OS then I'd recommend starting a support case to get a tech working on it.
• linkedin •
Old 04-27-2022, 06:35 PM
DetroitT's Avatar
DetroitT DetroitT is offline
2022.4 felling good here back on Mojave, 2010 cMP-12core intel, Radion 580
Mac Studio M1Max Monterey 12.3.1 on par with above while working. Excels in starts-ends-restarts. My issues here are / were Audio drivers only able to work internally. TB3 external still no go.
Old 04-27-2022, 10:50 PM
Maybe it's a Mojave 12.3.1 thing? I'm not sure whats going on but its weird. I tried installing the 2021.7 build but it started throwing up Avid Video Engine errors and video playback was broken. It kept saying it wasn't compatible with my OS. But, I can go even FURTHER back to 2021.12 and it all works fine. I really want my CLIP FX back... Bizarre...
Old 04-28-2022, 10:16 AM
Eric Lambert's Avatar
Fine here. Solid update.
Old 04-28-2022, 11:01 AM
Southsidemusic's Avatar
Stable amd snappier here too on macOS Catalina and Big Sur. Not an issue so far with Virtual Instruments.
Best Regards
Christopher
#thestruggleisreal
South Side Music Group
WEBHOME
Old 04-28-2022, 11:09 AM
Daveporter33765 Daveporter33765 is offline
No issues here with virtual instruments running in ProTools Studio on my 2020 iMac running Mac OS 12.3.1.
Luna 1.5.5, Logic Pro 10.8.1/Logic Pro 10.7.9, Cubase Pro 13.0.30, Studio One Pro 6.6, Pro Tools Studio 2024.3.1, PreSonus Quantum 2, UA-2 Software 11.2, UA Apollo 8, UA Apollo Twin Mk 2 (2), UAD-2 Thunderbolt Satellite Quad (2), Fractal Axe Fx III Mk. II Turbo FW 25, USB FW 1.15 and Axe-Edit III 1.13.19, Studio A: Apple iMac 2020, i7 8-core 3.8 GHz, 64 GB RAM, 1 TB SSD, RP5700XT GPU, 10 Gb/s Ethernet, MacOS Ventura 13.6.6. Studio B: Apple iMac 2015, i7 4-core 4 GHz, 64 GB RAM, 1 TB SSD, RP395X GPU, 1 Gb/s Ethernet, MacOS Monterey 12.7.1.
Old 04-28-2022, 12:58 PM
nsureit nsureit is offline
Smooth install, no issues whatsoever. PT Ultimate Perpetual, installed through AVID Link. Dell XPS 15 laptop, Windows 10. Although, I did hold my breath during HDX card firmware update.
2022 update: routing Mac Built-In audio to PT? Eric Lambert Pro Tools 27 05-13-2022 12:41 PM
Pro Tools plug-ins bundle 2022.2 update? MacMax Pro Tools 2 03-30-2022 07:27 AM
Jan 2022 Apple Security Update bricking display again OAG Avid S1, S3, Dock and Control App 2 01-04-2022 09:46 AM
Pro Tools Ultimate Perpetual License (Update + Support expires 2022) starlingmusic Buy & Sell 0 04-17-2021 09:20 PM
Haiti Disaster Donation Update RussUK General Discussion 0 02-13-2010 08:28 AM
