Digi PRE or MIDI I/O?
Hello! I know the Digidesign 192 I/O’s are currently working with Pro Tools 2021 but does anyone know if either the older MIDI I/O or PRE work?
Also, is there a separate firmware for the older 192 I/O or does it “just work” with the software installer? Thanks!!
Armando |
Re: Digi PRE or MIDI I/O?
I had a MIDI I/O for a long time and really liked it. Maybe two or three years ago it became kind of a PITA. I would have to reinstall the driver and then plug it back in to get it to work.
I bought the cheapest MOTU 8x8 and it's been rock solid. Loved the Digidesign one for years but don't miss it. Did look cool with my 192s. The 192 shows up as a 192 still from what I remember, but this would have been a few versions back. I'm using SSL AlphaLink now, which shows up as 3 192s.
Apple M1 Mac Studio (base model) ProTools Carbon w/SSL XLogic MADI-AX Instagram: https://www.instagram.com/sparkletune/ |
192's work just fine.
MIDI I/O only had a 32 bit driver so became a doorstop with Catalina. Shame because it did match PRE should work but you'll need a new MIDI interface to control it.
~Will |
The Pre is an all analog 8 channel mic preamp. I have one in my studio.
The only connection to PT is via MIDI which is so you can control the preamp settings inside Protools, you can also do that via the front of the unit as well. |
Is there a factory reset for the Pre, or a firmware update?
Not that I'm aware of. If you have a PRE and it's not working, it's a costly repair, I had mine repaired at the place below years ago (not sure if they still do it). The PRE remote control over MIDI still works for me using Pro Tools. Pairs nicely with the Quantum 4848 and I like that it has a line in/out on every channel if you want to insert a compressor or eq. Quality wise it's pretty neutral preamp and the stepped gain makes setting levels sometimes a bit tricky. Still nice big meters on the front panel.
Peter Toms [email protected] Condor Electronics Inc. 10007 Aurora Ave N Seattle WA USA 98133 206 633 5190 206 633 0803 fax
Justin (Proud Pro Tools Ultimate PERPETUAL license owner) Admin www.elevenrackpresets.com Studio: 2021 Mac Studio Ultra M1 20 Core CPU, 48 Core GPU, 64GB Ram, 4TB SSD boot | Pro Tools Ultimate 2022.12 | PreSonus Quantum 4848 interface| MOTU 112D interface | Digi PRE, FR OctoPre MKII, Mackie Onyx 800R, Panasonic WZ-AD96M (x2) and DA7, Eleven Rack, Apogee Big Ben, Mercury, Rode K2, Slate VMS ML-1 (x2). Laptop: Dell Inspiron 5559, i7-6500U 2.6Ghz, 16 GB RAM, 15.6" 1920x1080 1TB SSD |
I started having issues with my MIDI I/O after one of the High Sierra updates a few years. Bought a MOTU Micro Lite to replace it.
. System info https://duc.avid.com/member.php?u=57185 "please stop OVER-complicating simple things" |
Audio MIDI setup says DIGI 002 midi device is offline | oliarnalds | MIDI | 17 | 10-23-2016 10:13 PM |
Digi MIDI i/o Duplicated and greyed in Audio/Midi setup | xxicjoy | MIDI | 69 | 08-02-2013 08:40 PM |
Digi MIDI drivers cause Reason 6 'Failed to open MIDI support library' | davegibbon | Pro Tools 9 | 1 | 05-16-2012 04:08 AM |
Three MIDI ports on DIGI 002R within MIDI studio Setup | Chris7514 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 1 | 02-18-2010 04:57 PM |
Digi, When Protools creates MIDI regions after recording MIDI info.... | Mt.Everest | Pro Tools TDM Systems (Mac) | 0 | 07-21-2001 12:12 AM |
