Has anyone observed the TC VSS3 plugin not remembering it's settings when re-opening a session. It continually comes up in "default" setting regardless of what I have it set to when the session is closed. I have the other two TC System 6000 reverbs and they both retain their settings as they should. I'm running PT8.0cs2 on a MacPro Quad-Core. HD Accel 6 with a Magma PE6R4. Best, JSR |
Yep - I get the exact same thing here. A real PITA.
PT 8.0cs3 MacPro 2 x 3Ghz Quad HD3 Accel |
![]() Quote:
It retains its settings-- it just doesn't change the name. If you automate settings it does this too. You can hear it change but the name stays the same on the main page. Have you checked the other settings to see if they are at default? |
JSR,
Your VSS3 is acting correctly. Here is a response by TC about the issue: ======================================= I just wanted that confirmed outside TC, we are not able to fix that right away, we need some input from DIGI on that one. But if you noticed the Default that loads after reload, has all the parameters of "PLNReel1dia"... I really appreciate you help, thanks a lot. ======================================= I brought this up to them back in Feb. 09 as I was working with them on some other issues I was having with the VSS3.My example in another e-mail was I want it to save the name such as "PLNReel1dia". So, it is acting normal. I believe that "Revibe" exhibits the same issue.
Marti D. Humphrey CAS aka dr.sound www.thedubstage.com IMDB http://www.imdb.com/name/nm0401937/ Like everything in life, there are no guarantees just opportunities. |
I can confirm this at least on my system. Setting are retained, but the patch name is always default. A little unnerving at first, but seeing how the audio is correct, I can live with this for now.
update:
From what I can tell this is a different, but related issue: I have recently noticed that my VSS3 TDM loses its settings every time I open a session. The graphics are recalled, but the audio output is incorrect. All I have to do is click on any parameter and the audio suddenly conforms to the GUI. This happens EVERY time. I have trashed PT preferences with no improvement. I am running PT 8.0 cs3 on a Macpro quad 2.6 and OSX 10.5.6 I would prefer NOT to update PT or my OS because ALL of my other plugins are working flawlessly. Anyone else having this problem? |
Thanks a lot for the information! I was about to get the TDM versions instead of my Powercore versions, but I guess I will wait a little...
iMac Pro - HDX2 - Mojave - AVID HD I/O x7 |
Been using VSS3 since 7.4 and have never had this problem ![]() Its in my mixing template and recalls presets and settings fine! Chris
Yes it's pretty damn odd...
Just for the record, presets recall fine. The settings maintain as long as the session is open. But EVERY time a session is opened, VSS3 outputs something seemingly random (somtimes over 3 seconds of reverb, sometimes under 500ms). As soon as I touch ANY parameter, BANG....everything is as it should be. The gui is fine all along except for the program title which remains as DEFAULT no matter what preset is selected. TC has bee ZERO help here. No replies to email support or phone support and for the record, I have maintained a polite, professional tone in my requests for help. Thanks TC. ![]() Z |
Have you tried trashing preferences or testing from a new administrator account?
Recalling settings from track | Gonk | Eleven Rack | 2 | 09-02-2013 01:25 PM |
EQ3 Not recalling/saving settings | slaterweezer | Pro Tools TDM Systems (Mac) | 0 | 04-09-2012 11:42 AM |
PQ User settings not recalling | noclevername | VENUE Live Sound Systems | 6 | 06-21-2010 08:20 AM |
Is there a Bug® with recalling zoom settings?? | Bushpig | Pro Tools TDM Systems (Mac) | 11 | 07-13-2009 03:49 PM |
FilterBank settings not recalling? | Eric Lambert | Pro Tools TDM Systems (Mac) | 1 | 06-13-2002 12:05 AM |
