Old 10-22-2013, 08:04 AM
jgagne1 jgagne1 is offline
Default Pro Tools 11 always opens with the "All" group enabled?
Is there a setting to stop this or is it just a bug? It's pretty annoying as if I go to mute one track, it mutes them all (because I never realize that the ALL group is enabled), and then if I unmute all the tracks, any tracks that I wanted to be muted are now unmuted.
Is there a fix?
Old 10-23-2013, 10:17 AM
Default Re: Pro Tools 11 always opens with the "All" group enabled?
does this happen to anyone else?
Old 10-23-2013, 10:24 AM
philgrab philgrab is offline
Yes.
Old 10-23-2013, 02:59 PM
Does not happen here. I wonder if this old trick would help(assuming you run Windows as you gave zero information about your setup). Once you have the ALL group turned off, close the session with the Alt-F4 command(which will close Pro Tools). You might also try building a session template to cover your usual needs, and disable(or remove) the ALL group before you save as a template. See if that helps with new sessions.
Old 11-08-2013, 06:14 AM
remute remute is offline
This is happening to me 11.02, Mountain Lion.
Deeply fecking annoying.
Every session starts with having to click the "your I/O settings" box then disabling the ALL group and then waiting for the click to start randomly going off.
Anyone found a solution yet?
Old 11-08-2013, 03:26 PM
K Roche's Avatar
K Roche K Roche is online now
Not happening here either, I'm on 11.0.2 ...OSX 10.8.5
System :
Avid Carbon interface , PT Ultimate 2021.3.1 .....Mid 2020 iMac 27" 3.8GHz 8-core i7 10th Gen processor,,128GB 2666MHz DDR4 memory,,2TB SSD storage,,Radeon Pro 5700 XT with 16GB of GDDR6 memory,, on Catalina 10.15.7
"Peace cannot be kept by force. It can only be achieved by understanding" Albert Einstein
Enjoy the Journey
.... Kev...
Old 11-08-2013, 04:29 PM
Southsidemusic's Avatar
Hi
Tried on both our studio room setups and it hasn't happened here once
However we only use Mac here and OSX 10.8.5 PTHD11 and HD10
Best
Chris
Best Regards
Christopher
#thestruggleisreal
South Side Music Group
WEBHOME
"ALL" Group behavior in Pro Tools 9 innerbooty Pro Tools 9 0 03-07-2014 10:23 AM
pro tools crashes when modifying group "all" mortenbrekke Pro Tools 11 1 07-07-2013 10:17 AM
v9.0.3 never opens with proper digi "clock source" glankrudolph Pro Tools 9 3 04-12-2013 09:45 AM
Horrible Delay and Reverb on "record enabled" in PTLE 8.0 jbandhisguitar 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 4 12-28-2009 10:32 AM
MTC input disabled when "Beat clock to port.." or "MTC to Port..." is enabled OKden Pro Tools TDM Systems (Mac) 2 10-27-2001 03:24 AM
