Old 05-20-2014, 07:59 AM
abes abes is offline
Default Glitchy audio when using Video PCI Out via Blackmagic
Im currently using PTHD 10.3.8 and my session is around 90 audio tracks, some with reverbs, e.q etc and some with none, just audio.
I've cached about 16GB of the session and I have 32GB in total in my Mac.
The whole 1hr 30min film plays out perfectly with no errors on my 2 monitors, but when I use PCI Video Out in order to view via the projector, using my Blackmagic Mulitbridge Eclipse, I'm getting loads of glitches and drop outs.
I've noticed that if I disable quite a few tracks the video and audio plays out fine.
Is there some sort of glitch I'm unaware because of an update? I worked on a film earlier in the year with more tracks and everything played out fine.
I've tried all the recommended videos codecs, I've got the video, PT session and PT system all on different hard drives, tried a new HDMI lead, tried the SDI output and now I'm totally lost.
My specs are:
PTHD 10.3.8
Blackmagic Multibridge Eclipse 9.5.3
Mac 10.6.8
2 x 3.2GHz Quad-Core Intel Xeon
32GB Ram
Anyone else had this issue?
Old 05-21-2014, 08:37 AM
reichman's Avatar
reichman reichman is offline
Default Re: Glitchy audio when using Video PCI Out via Blackmagic
On paper, your system should be rocking. Most of us have the BM Intensity Pro, that Eclispe is the only odd thing in your system.
This is a long-shot, but have you tried uninstalling/re-installing the BM drivers?
I find most Macs perform better with Blackmagic, not worse.
Nathaniel Reichman
Producer/Re-recording Mixer - New York
Nathaniel Reichman | IMDB | LinkedIn
Old 05-22-2014, 02:54 PM
I did try uninstalling the BM driver and updating with new ones but nothing works.
Really confusing as my system is running at 50% with 100+ tracks, but soon as I use PCI Out, the audio goes glitchy, but the system is still running at 50%
Maybe I should update my MAC O SX as I'm still using Snow Leopard. I don't want to use Mavericks as I'm sure most of my plugins won't run with it.
Really confused as the video worked fine on PT 10.1 (maybe that's my answer!)
Old 05-22-2014, 02:57 PM
Also, could I use the BM Intensity Pro alongside my Eclipse?
HTML code is On
No video out to Blackmagic intensity pro redsixmix Pro Tools 11 3 01-16-2014 11:02 AM
Glitchy Audio ProjectMix I/O haam Pro Tools M-Powered (Mac) 6 02-25-2010 09:29 PM
Please help, glitchy video on PT LE. tokolosh Post - Surround - Video 17 08-27-2009 07:21 AM
new Blackmagic video products reichman Post - Surround - Video 1 04-20-2009 03:18 PM
Glitchy audio since 6.4? jccrtv 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 05-12-2004 06:47 AM
