DAT, CD, Masterlink, what to use?
What format is the best for delivery to a mastering house assuming they have all of these available. I recently heard that DATs are actually better than CDrs? Does anybody know if this is true? If so, does the masterlink have the same inherant problems? Would a 24bit DAT be prefered to a 24 bit CD from masterlink?/????
Re: DAT, CD, Masterlink, what to use?
Good question.
These recent discussions seem to say that CDR would be better than DAT, and better yet would be to send the 24-bit Wave or SD2 files on CD-ROM. The best thing to do would be to ask your mastering house. They know what they want. http://duc.digidesign.com/ubb/Forum2/HTML/002437.html http://duc.digidesign.com/ubb/Forum2/HTML/003839.html ------------------ Chris Droessler www.barnabas.com Barnabas MultiMedia
www.barnabas.com Barnabas MultiMedia |
Remember beegster.. It's all 1 & 0's till someone gets hurt. There will be no sound difference between the mediums you mentioned if you go in digital. It's just information. Barnabas is right just ask the guy who is going to master. The place where I master most takes all.
Bro, how reliable do you need? When you go to mastering you only play it in once... Go with compatibility. If your mastering guy wants dats, give dats. Dig in and dig out it's only 1 and o's. Masterlink is only a stand alone unit made of a hard drive and cdr. Go with what works for you.
ooh yeah... Your mastering guy may be out to lunch!! Send it to me to master it!
There are a couple of big differences between the fomats:
Error rates : Both DAT and CD use playback error correction. CDROM or HD don't. DAT has a higher error rate than CD (I don't have figures on me). D/A converter : Obviously the D/A in the mastering house on their DAT will be different to their CD player, unless they are using external conversion (you'd hope so!). Does that help? Anyone else have more info? |
What system does your mastering house use? If they use any type of workstation you can probably save your files in a format that they can load. For example many mastering houses use Sonic Solutions which should be able to open 16 or 24 bit AIFF files.
Dual 2.3 GHz PowerPC G5 2.5GB RAM OS 10.4.6 HD 2 Accel PT 7.1cs9 192 I/O |
Yes. Recordings to standard (redbook) audio cd's and DAT's will always contain some errors due to the limitations of the media. Depending on the severity of the errors, they are either corrected (with error correction codes embedded in the data) or masked (using some sort of interpolation scheme).
The best bet is to use a file format such as AIFF. Data files will always be bit-for-bit accurate. |
yes, but what do you deliver the aiff file on? will a CD reader reading your cdr have no error rates?
Masterlink with 002 | WRX07 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 1 | 03-14-2006 05:15 AM |
Masterlink as A/D? | KaProducer | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 18 | 07-11-2005 12:51 PM |
Masterlink and 002 | vicwind | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 6 | 09-19-2004 07:12 PM |
Masterlink ? | sugarfuzz | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 8 | 06-16-2004 02:46 PM |
MASTERLINK | LCM | Pro Tools TDM Systems (Mac) | 0 | 03-20-2000 12:33 AM |
