Problem when I try to Play a proyect
hello, I have this problem when I try to play Pro tools.
access violation ocurred, unable to read location : 0x0084700c at address: 0x77a43913 in module : ntdll.dll PT is not crash, the problem is that I can not to play the proyect... It happens usually after a few hours, but is very common. any Idea about it?? Windows 7 x64 (ultimate) digi 003 rack, pro tools 8.03 LE cs1 (with drivers for windows 7 x64) Mother asus p6t, 6gb ddrm corsai, intel i7 920. I an ussing the autobackup. Pablo |
Re: Problem when I try to Play a proyect
Pro Tools Power User Editing Give your plug-ins a facelift...and skin 'em! __________________ "Music should be performed by the musician, not by the engineer." Michael Wagener 25th July 2005, 02:59 PM __________________ Pro Tools|HD Native 9.0.1 | Pro Tools|HDX 10.2 | Studio One | REAPER 4.22 | HD OMNI | HoboMac Pro 2.26Ghz Quad-Core | W7 Ultimate 64-bit |
I put the Sandra report in rar file.
thanks Pablo http://www.hispasonic.com/comunidad/...e.php?id=97622 |
Click on computer overview, then copy to clip board and paste it here in this very thread so we can all quickly see it.
Shane
thanks! I didn´t know how to use that software.
I copy the information Pablo SiSoftware Sandra Computer Model : System manufacturer System Product Name Workgroup : WORKGROUP Host Name : lamandolina-pc User : La Mandolina Processor Model : Intel(R) Core(TM) i7 CPU 920 @ 2.67GHz Speed : 2.8GHz Cores per Processor : 4 Unit(s) Threads per Core : 2 Unit(s) Type : Quad-Core Integrated Data Cache : 4x 32kB, Synchronous, Write-Thru, 8-way, 64 byte line size, 2 threads sharing L2 On-board Cache : 4x 256kB, ECC, Synchronous, ATC, 8-way, 64 byte line size, 2 threads sharing L3 On-board Cache : 8MB, ECC, Synchronous, ATC, 16-way, Exclusive, 64 byte line size, 8 threads sharing Computer Mainboard : Asus P6T BIOS : AMI 0603 05/19/2009 Bus(es) : ISA X-Bus PCI PCIe IMB USB FireWire/1394 i2c/SMBus Multi-Processor (MP) Support : No Multi-Processor Advanced PIC (APIC) : Yes Total Memory : 6GB DIMM DDR3 Chipset Model : ASUS X58 I/O Hub Front Side Bus Speed : 2x 2.41GHz (4.82GHz) Chipset Model : Intel Core CPU Generic Non-Core Registers Front Side Bus Speed : 2x 2.41GHz (4.82GHz) Total Memory : 6GB DIMM DDR3 Memory Bus Speed : 2x 536MHz (1GHz) Memory Module(s) Memory Module : Corsair CM3X2G1333C9 2GB DIMM DDR3 PC3-10700U DDR3-1334 (9-9-9-24 5-34-10-5) Memory Module : Corsair CM3X2G1333C9 2GB DIMM DDR3 PC3-10700U DDR3-1334 (9-9-9-24 5-34-10-5) Memory Module : Corsair CM3X2G1333C9 2GB DIMM DDR3 PC3-10700U DDR3-1334 (9-9-9-24 5-34-10-5) Video System Video Adapter : NVIDIA GeForce 9800 GT (2x 112 SM4.0 1.4GHz, 2x 512MB DDR3 2x900MHz, PCIe 2.00 x16) Graphics Processor Adapter : NVIDIA GeForce 9800 GT (2x112SP 14C 1.5GHz, 2x512MB 2x900MHz) Adapter : NVIDIA GeForce 9800 GT (2x495.6MB 2x900MHz) Storage Devices WDC WD5000AAKS-00D2B0 (500.1GB, SATA300, 3.5", 7200rpm, NCQ, 16MB Cache) : 466GB (C:) (F:) WDC WD3200AAKS-00VYA0 (320GB, SATA300, 3.5", 7200rpm, NCQ, 16MB Cache) : 298GB (D:) WDC WD5000AAKS-00D2B0 (500.1GB, SATA300, 3.5", 7200rpm, NCQ, 16MB Cache) : 466GB (E:) ATAPI iHAS122 A (SATA150, DVD+-RW, CD-RW, 2MB Cache) : N/A (G:) Logical Storage Devices SISTEMA (C:) : 146GB (NTFS) @ WDC WD5000AAKS-00D2B0 (500.1GB, SATA300, 3.5", 7200rpm, NCQ, 16MB Cache) PROYECTOS (D:) : 298GB (NTFS) @ WDC WD3200AAKS-00VYA0 (320GB, SATA300, 3.5", 7200rpm, NCQ, 16MB Cache) LIBRERIAS (E:) : 466GB (NTFS) @ WDC WD5000AAKS-00D2B0 (500.1GB, SATA300, 3.5", 7200rpm, NCQ, 16MB Cache) LIBRERIAS 2 (F:) : 319GB (NTFS) @ WDC WD5000AAKS-00D2B0 (500.1GB, SATA300, 3.5", 7200rpm, NCQ, 16MB Cache) 3.5" 1.44MB (A:) : N/A Optical Drive (G:) : N/A @ ATAPI iHAS122 A (SATA150, DVD+-RW, CD-RW, 2MB Cache) Peripherals LPC Hub Controller 1 : ASUS LPC Interface Controller LPC Legacy Controller 1 : T0 A5-13h Audio Device : ASUS HD Audio Controller Audio Codec : Realtek Semiconductor 888 High Definition Audio Disk Controller : ASUS 4 port SATA IDE Controller Disk Controller : ASUS 2 port SATA IDE Controller Disk Controller : ASUS JMB36X PCIE-to-SATAII/IDE RAID Controller USB Controller 1 : ASUS USB UHCI Controller #4 USB Controller 2 : ASUS USB UHCI Controller #5 USB Controller 3 : ASUS USB UHCI Controller #6 USB Controller 4 : ASUS USB EHCI Controller #2 USB Controller 5 : ASUS USB UHCI Controller #1 USB Controller 6 : ASUS USB UHCI Controller #2 USB Controller 7 : ASUS USB UHCI Controller #3 USB Controller 8 : ASUS USB EHCI Controller #1 FireWire/1394 Controller 1 : ASUS 3403h FireWire/1394 Controller 2 : VIA VT6306 VIA Fire II IEEE-1394 OHCI Link Layer Controller SMBus/i2c Controller 1 : Intel 801xx/63xx SMBus Printers and Faxes Printer : Microsoft XPS Document Writer (600x600, Colour) Fax : Microsoft Shared Fax Driver (200x200) Network Services Power Management Mains (AC) Line Status : On-Line Operating System Windows System : Microsoft Windows 7 Ultimate 6.01.7600 Platform Compliance : x64 Windows Experience Index Current System : 5.9 |
I have configurated windows 7 following the digitech website information.
Today works perfect, but is really common this error. I am composing the music for a film (not a short film) and I spend a lot of time with this error... Pablo |
I'm not sure if those RAM timings are ideal for your system. You'll probably need to do some BIOS optimizations. Some of the i7 users will probably chime in. Having said that, I would not be doing any serious work on W7 64, especially film work, since it is still in beta. I suggest a dual boot for now using XP Pro SP3 and PT 8.0.1cs1. W7 64 isn't ready for prime time as it's still in beta.
Shane
Bumping this so an i7 user can check out your RAM timings.
Shane
Shan!
Thanks, so you think perhaps is a timing memory problem???¡? Where can I found a better configuration for my I7? I´m ussing the 1394 on board port, (asus p6t) do you know if it is the best or Should I buy another 1394 pci card? Gracias! Pablo |
Shane
odd play/record problem | Craig F | Pro Tools TDM Systems (Mac) | 0 | 02-21-2007 08:14 PM |
Play back problem | oneblood | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 3 | 10-27-2005 12:25 PM |
Strange Play Problem. | Rabre | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 2 | 05-16-2005 07:52 PM |
play and stop problem | earhythmic | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 4 | 07-23-2004 02:17 PM |
Help on new proyect | lazymits | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 2 | 12-08-2003 09:08 AM |
