Old 04-11-2009, 04:44 PM
Mason00 Mason00 is offline
Default MIDI Editor Piano Roll New Feature!
It would be great if the MIDI Editor in Pro Tools allowed us to rename/change the note names in the Piano Roll to suit our sessions. This is a great feature for easier MIDI editing erasing the need to click on each piano key to figure out what sound/sample is there..
Example: C3, C#3, D3, can be renamed Kick Drum, Snare, Hi Hat, etc
I'm surprised Digidesign didn't implement this into Version 8. It's never too late Digi...This is a great feature.
This has been available in the Piano Roll in FL Studio for years.
(PT12.4- Win7Pro - mboxpro3 -Axiom25- Maschine)
Old 04-12-2009, 04:47 PM
Default Re: MIDI Editor Piano Roll New Feature!
An alternative could be to setup multiple MIDI tracks in Single Note View naming these to reflect drum instruments and using the Superimposed Note View with 'Color Code MIDI Notes by Track' enabled.
filosofem
Old 04-13-2009, 06:53 AM
Thing is, this feature is all about SPEED. Like assigning 12 different samples to the pads in Transfusers Drum Synth and then recording what I bang out to ONE MIDI/INSTRUMENT track in PT8 using my M-Audio Trigger Finger.
I don't want to then have to figure out when I'm editing in the MIDI Editor what sound each key in the piano roll represents. Renaming C3 to KICK, C#3 to HI-HAT, D3 to GIRL VOCAL SNIPPET, D#4 to CRASH, etc is what I'm talking about for MY WORKFLOW.
Your alternative solution is workable, but my recommendation is faster.
Old 04-13-2009, 07:19 AM
flommer flommer is offline
Your solution is not any faster if you set up a template once, and then use that any time you are starting a new session.
There are other editing advantages to having each drum on it's own track.
MacPro3ghz, 6GB, 10.7.5, PT10.3.2, Digi002 factory/toolkit2/PTIEP, 11R
Old 04-13-2009, 04:06 PM
musicalavtech musicalavtech is offline
What they say works niiice! PT8 can't rename the piano roll notes yet.
OSX10.6.8, 1st gen Power Mac,
PT8.0.5, Mbox2
Is there a key command to bring the new piano roll editor pane up? Ru_C Pro Tools TDM Systems (Mac) 2 03-14-2011 11:04 PM
midi selections in midi editor with piano roll matt_the_manic MIDI 5 09-27-2010 03:16 AM
Feature Request Midi Editor mhmh Pro Tools TDM Systems (Mac) 0 01-28-2009 07:26 AM
piano roll in midi track pietervd Tips & Tricks 2 02-24-2006 07:10 PM
Insert MIDI notes w/ mouse on 001 piano roll scuppari 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 4 01-20-2003 09:01 AM
