Old 10-13-2021, 04:58 AM
Default Re: How to make midi notes look big
Originally Posted by Samba View Post
I've just wiped my laptop.
New specs: Big Sur 11.6 & Pro Tools 2021.7
The problem still exists. Midi notes always look small when in full screen.
Does Avid actually provide a way to set this so it's able to be set? Or is it a luck of the draw?
As I said before - once I set a size it stays there. There's no setting that says 'keep this note size'. Can you adjust the note size at all and if so does it stay that size when you save and close the session and reopen said session? Does it stay the set size when you quit and restart PT?
Jack
QAPLA!
Old 10-13-2021, 09:32 AM
Ben Jenssen's Avatar
Silly question from one who doesn't edit midi in PT that much; Is it a matter of one of you talking about midi in the edit window, and the other about the midi editor window?
Old 10-13-2021, 09:45 AM
midnightrambler midnightrambler is offline
If we're talking about the main edit window (not the MIDI editor), mine doesn't "remember" the size either. It doesn't even remember it from track to track.
Old 10-13-2021, 10:34 AM
Eric Lambert's Avatar
PT 2021.7.0 w/ OS 11.6. If I enlarge MIDI notes using **** + command + ] and then hit E for full screen, the size is consistent between both zoom levels. From memory, it has always operated that way.
I'll check with some of the other guys I work with and see how their rigs behave. This would be frustrating. It doesn't feel like a bug per se, it feels like there's a setting that got tripped, or your PT preferences file has gone corrupt. You reinstalled PT but I'm not certain that your old preference file isn't still being accessed.
If it were me, I'd clear out that pref file and start a new session (the behavior might be saved with your old, existing old session) then retest. This is fixable.
Also, how do you have your Preferences set in the Editing/Zoom Toggle tab? There are a few adjustments in there that could be complicating things if not properly set.
Old 10-13-2021, 01:01 PM
That could be. I never edit MIDI in the edit window but in the MIDI editor window.
Jack
QAPLA!
  #16
Old 10-15-2021, 03:01 PM
Samba Samba is offline
Default Making midi notes bigger
I'm on Big Sur 11.6 & PT 2021.
When going full screen, midi notes are too small to edit. I have to manually make them bigger. This wastes time.
I've asked this question before, but no-one seems to know if Avid has provided a definite way to ensure midi notes are always an editable size when going full screen.
I can't see an option in preferences. Surely it's possible?
  #17
Old 10-15-2021, 06:06 PM
Default Re: Making midi notes bigger
You already have an ongoing thread about this.
https://duc.avid.com/showthread.php?t=416872
  #18
Old 10-15-2021, 07:47 PM
I know. I'm still waiting for an answer. I thought this would be a pretty basic question.
  #19
Old 10-17-2021, 10:12 AM
No response to the post above so the thread has gone dead. FWIW I was able to adequately adjust MIDI note size behavior by adjusting Preferences.
Make midi notes fatter Samba Pro Tools 2020 4 12-09-2020 10:56 AM
How to make notes to a each playlist? Sir Hannes Getting Started 4 09-14-2018 07:51 AM
Quatize make short notes Shasho macOS 1 07-11-2013 09:13 AM
Make MIDI Track Notes Bigger bugnut 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 2 06-12-2008 02:47 AM
Hey, why DIGI make midi notes flat in 6.7...??? Valentino 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 24 12-04-2004 09:19 PM
