Old 05-01-2009, 06:04 PM
WildHoney WildHoney is offline
Default Ergotron monitor arms
Anybody ever used these? I'm thinking of getting this dual model for a C24 station with 2x20" widescreens lcd's.
http://www.ergotron.com/Products/tab...B/default.aspx
Old 05-01-2009, 07:00 PM
Craig F Craig F is offline
Default Re: Ergotron monitor arms
I've used the singles
they work well
Thank you,
Craig
Old 05-01-2009, 09:29 PM
TCLguy1 TCLguy1 is offline
they work well
I am using two of the singles, they are great.
Best,
TCLguy
_________________________________________
12-Core Xeon 3.33, Antelope Audio Goliath, Logic, Live, PT12HD
Dual 2.7 G5, ProTools HD3, 2*192's, SSL Delta Link
iMac 3.0 , Abelton live
MacBook Pro, Logic X for Video
Old 05-02-2009, 07:25 AM
Mark Dann Mark Dann is offline
I've had one for years now. Currently it holds a 24" monitor over the master section of a rather large console. It's attached to the wall behind it. There is simply no other way I'd be able to get this (or any) monitor where I want it. It was $300., but more than worth it.
Old 05-02-2009, 09:30 AM
Vaphoron Vaphoron is offline
I've finally decided to get two of these because I'm gonna be adding another monitor or two to my workspace and can't fit them any other way. I was looking at a dual one but the singles are way cheaper and more flexible so I'm just gonna go that route.
- Jason
Old 05-02-2009, 09:33 AM
Any idea what the difference between that model and the LX model which is nearly twice the price? see link: http://www.amazon.com/Ergotron-Desk-...JSVMC9AEP4YVMX
Old 05-02-2009, 11:58 AM
usastra usastra is offline
Probably the sturdiness... I have the LX and really think it's worth it.
Old 05-02-2009, 12:07 PM
The difference between those two mainly seems to be a different design and monitor size/weight capability. The cheaper one says it supports up to a 22" 18lb monitor and the more expensive one a 24" 20lb monitor. I currently have two 22" LCDs that I'm planning to mount but I would like to have the option to move up to a 24" later. I looked up the weight of a 24" and it was 15lbs without the stand which leads me to believe that they would work just fine on the cheaper Ergotron since it doesn't exceed the 18lb mark. I think the monitor sizing is more of a guideline than an actually limitation unless dealing with one of the multi-monitor stands. I'm just gonna go by the weight limit since the VESA mount size is the same.
- Jason
Old 05-03-2009, 01:47 AM
mix109 mix109 is offline
The quality and ergonomics of the Ergotron Products is really great.
On the C24 room we have exactly the product that WildHoney mentions,mounted on an Argosy C24 Furniture,with (2) 22' Samsung Displays.
We omly needed to trim a bit the mounting pole of the Ergotron.
Old 05-03-2009, 02:57 AM
steins steins is offline
I've used Ergotron arms for years, never a problem with them. Great product!
Stein Tore
Selecting Instrument Track Auto Rec Arms Connor Pro Tools 11 1 07-26-2013 06:18 AM
Replacement monitor arms for D-Control Console quadraphonics Post - Surround - Video 0 01-10-2012 06:45 AM
record track un-arms after stop! soundwavve Pro Tools TDM Systems (Mac) 3 07-30-2008 08:16 AM
Best LCD Monitor Arms Joe Mendelson Post - Surround - Video 3 02-18-2008 11:41 PM
LCD Monitor Arms mondoJML Post - Surround - Video 10 05-24-2007 12:47 PM
