Vocal track not bouncing!
Here's a weird one:
I was trying to bounce a track this morning, first in MP3 format, then as an aif file. The mp3 (160kHz) sounded horrible! So I tried to bounce the track as an aif. Everything bounced EXCEPT the vocal track. When I went back to the mp3 I originally bounced, no vocal track there either. The instrument tracks are fine.. all outputs set to 1-2. When I audition the mix, the vocal's fine.. just on bounce. I had POD Farm as an effect on the track and took it out as I thought it might be the culprit. Didn't change anything. Anyone else run into something similar?
“What fresh hell is this?” - Dorothy S. Parker |
Re: Vocal track not bouncing!
You could route it all to an audio track and record it to track instead of bounce to disk, then export audio file after.
Try that to see if the vocals stay.
www.mikeslatermusic.com PTHD9 Certified Operator 15" MBP 10.7.2 Pro Tools 10.0 Apogee Duet M-Audio BX5A's |
*later that night* dang... figured out the problem.... dumbest thing I've ever done in Pro Tools. Sheesh.
“What fresh hell is this?” - Dorothy S. Parker Last edited by Darney; 04-30-2011 at 12:58 AM. Reason: solved problem |
EQ Presets for Vocal Less Track | Becharax | Pro Tools 11 | 9 | 08-26-2013 02:46 PM |
Ageing a vocal track | nicosonoro | Post - Surround - Video | 5 | 06-03-2011 02:07 PM |
Bouncing an Existing Track to a New Track | manonash | Pro Tools M-Powered (Win) | 2 | 09-07-2010 06:10 PM |
bouncing from instrument track to audio track | rolew | Pro Tools M-Powered (Mac) | 5 | 04-18-2009 02:01 AM |
vocal over 2 track | Busterman | General Discussion | 4 | 08-06-2003 08:14 AM |
