Old 03-18-2002, 07:29 PM
Viditte Viditte is offline
Default DB25 to DB25 snake
I am confused about the input of m 192 into the procontrol. I have a cable with normal tascam pin out arrangement. It is what was reccommended at my dealer. The routing is all wrong. I can't use the procontrol correctly. Where can I find PDF for the pin out. I need a soloution for this. I can get the cable built at a modest price with the right information.
Old 03-18-2002, 07:32 PM
Default Re: DB25 to DB25 snake
Dah, the output from 192 to procontrol input is what bugs me. TY
Old 03-19-2002, 04:47 PM
DigiTechSupt's Avatar
DigiTechSupt DigiTechSupt is online now
Hi
The DB-25 you need is designed for use with
192I/O and Procontrol.One DB25 pin is reversed (so, 1->8, 2->7, 3->6, etc.) to compensate for the reversed pin outs on ProControl.
Its called a DB25-DB25R ProControl DigiSnake, 25'
http://www.digidesign.com/p roducts/prd_overview.cfm?product_id=2586
MJ
Digidesign Tech Support.
Avid Audio Tech Support
Support FAQ
Old 03-25-2002, 05:35 PM
I have db25 breakout snakes to both xlrF and xlrM so I hook them up 1-8, 2-7,3-6, 4-5, 5-4,6-3, 7-2,8-1, and send the audio into the Procontrol audio 2 in. I output using db25-xlrM snake into the M&k powered speakers. I/O 5.1 routing LRLsRsCSub for procontrol. I was hoping everything was now straight forward. Snake channel 1 would be the Left front speaker. This wasn't the case. I'm missing it somplace. I need to show this badboy off in surround. Is the digisnake going to solve this? [img]images/icons/shocked.gif[/img]
Old 03-26-2002, 02:00 PM
Yes.
MJ
Support FAQ
Old 03-26-2002, 04:03 PM
I'm up and running in surround. Using signal generater and 5.1 output panned to the diffrent ch. and I am on the fly. The digisnake is a elegant soloution. [img]images/icons/wink.gif[/img]
PT HD AES/EBU DB25 doesn't match the others? studio rec Pro Tools TDM Systems (Mac) 7 03-10-2015 09:02 AM
192 DB25 pin out??? thephatboi Pro Tools TDM Systems (Mac) 7 01-03-2007 07:32 AM
WTB Digidesign DB25 to XLR Digi Snake RCKPROD ICON & C|24 0 11-01-2005 08:05 AM
4ft DB25 Cable Heinz Kohlbauer Pro Tools TDM Systems (Mac) 0 02-19-2003 06:26 AM
Anyone know if a Tascam CU/SD105 db25 to db25 will do the job? juniperjuniper Pro Tools TDM Systems (Mac) 2 05-22-2002 01:30 AM
