Old 05-21-2002, 12:54 PM
juniperjuniper juniperjuniper is offline
Default Anyone know if a Tascam CU/SD105 db25 to db25 will do the job?
Will a Tascam CU/SD105 DB25 to DB25 8 channel analog cable work on the Control 24 DB25 analog connectors? Are the pins the same?
This cable is made for the Tascam 2424 and is much less than other DB25 cables on the market.
Thanks.
Old 05-21-2002, 07:48 PM
leon777 leon777 is offline
Default Re: Anyone know if a Tascam CU/SD105 db25 to db25 will do the job?
I have the Tascam SD 403 DB 25 to TRS. I purchases it believing it would do the job of the
Digi DB 25 to TRS for the Control 24 and it does not work. It must have different pin
configuration.
Doesn't someone make a less expensive cable than digi with the same config?
Old 05-22-2002, 01:30 AM
Psyduck Psyduck is offline
Yep.
FS: Digisnakes DB25 to TRS also to AES francois Buy & Sell 11 05-23-2013 06:12 AM
192 DB25 pin out??? thephatboi Pro Tools TDM Systems (Mac) 7 01-03-2007 07:32 AM
4ft DB25 Cable Heinz Kohlbauer Pro Tools TDM Systems (Mac) 0 02-19-2003 06:26 AM
DB25 to DB25 snake Viditte ProControl, Control|24, Command|8 5 03-26-2002 04:03 PM
DB25-TRS - This has to be an error, right? Lee Blaske Pro Tools TDM Systems (Mac) 1 01-29-2002 12:46 PM
