are these two compatible with each other?
and if so, is there a limit on the number of tracks you can have? i'll be running this on a Powerbook 12" 1GHz |
Yes, someone help. The logic site and forums are not clear as to the number of simultaneous inputs supported. "Digidesign DAE" says "8" and "CoreAudio" says 128, neither of which sounds right.
MacBook Pro Core Duo 1.83 2 Gig RAM OS X 10.4.8 002R/PTLE 7.3.1 |
They are compatible. The trackcount is, I belive 128. Or 192. I have never reached the loft, trackcuont, that is, in logic.
Br Tubz |
I agree. I am using Logic Platinum 6.3.3 and Digi 002R/Pro Tools LE 6.2.3 on a G5 1.8ghz (OS X 10.3.2) and I right now am getting 50+ audio tracks in Logic. I know I could get more, I have just never had a need to go that high. But yes they are very compatible, Just remember when setting the Audio driver up in Logic do not use DAE, use Core Audio for any Digi002 product. It will show the Digi002 under Core Audio anyway.
Hope this helps. U-P "I am hip-hop."
Failure is not an option!!! |
The question I was asking was how many simultaneious inputs can you get. The 002R has 18 channels. Can all 18 be tracked into Logic at the same time?
Also, if you are using Logic, why would you be using ProTools?
![]() Quote:
Digi002 Rack plus Logic | ianmiller | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 0 | 04-08-2004 07:37 AM |
Will Digi002 be Compatible with Apple, oops, I Mean Emagic Logic Audio Platinum? | electrobank | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 1 | 07-20-2002 02:21 AM |
Logic Platinum! | Blake Henderson | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 7 | 08-26-2001 01:55 PM |
DAe and Logic Platinum | pSYCOb | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 1 | 09-06-2000 03:23 PM |
001 and logic platinum 4.5 | joshua7 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 2 | 07-24-2000 06:35 AM |
