Hi, I'm running:
Windows 7 Home Premium SP 1 Intel Pentium CPU g640 @ 2.70GHz 4.00 GB RAM 64-bit OS For some reason, after installing the Mbox drivers, the control panel for Mbox says "Hardware Not Connected." The speakers work just fine going through the Mbox, but it's not being recognized as connected, which means I can't use ASIO, which means I can't record with it, etc. The strange part is it used to work just fine on another PC running Windows 7 also. I've tried reinstalling, using different USB cables, running the installation as administrator, in compatibility with XP, etc. Tried switching to different USB ports. No matter what, in the Mbox control panel, it tells me the hardware is not connected. my recording software says the same. Thanks in advance for any help. |
No one knows anything? The Mbox will make a nice paperweight I suppose.
Not enough info for anyone to help. Hit this link:Help us Help You - READ THIS Before Posting! and have a good read. Then post a Sandra report and include the exact version of Pro Tools you have.
Gigabyte X79/intel i7 3930K, 32GB RAM, HD/Native, 192 IO https://www.facebook.com/search/top/...0sound%20works The better I drink, the more I mix ![]() BTW, my name is Dave, but most people call me.........................Dave |
I don't have Pro Tools. I opted for just the hardware. Either way, it's not being recognized by my computer.
i have the same problem. the drivers don't seem to work. Have downloaded 6 or 7 different versions. The Mac doesnt find the mbox mini and says same 'hardware not detected
Alright, I've got my report here:
SiSoftware Sandra Computer Model : Dell Inspiron 620s Serial Number : 9QH**** Chassis : Dell Desktop Mainboard : Dell 0GDG8Y Serial Number : ..CN7016********* BIOS : Dell A04 11/21/2011 Total Memory : 3.92GB DIMM DDR3 Processors Processor : Intel(R) Pentium(R) CPU G630 @ 2.70GHz (2C 2.7GHz, 2.7GHz IMC, 256kB L2, 3MB L3) Socket/Slot : FC LGA1155 Chipset Memory Controller : Dell Core (Sandy Bridge) DRAM Controller 100MHz, 2x 2GB DIMM DDR3 1GHz 128-bit, Integrated Graphics Memory Module(s) Memory Module : Nanya NT2GC64B88G0NF-CG 2GB DIMM DDR3 PC3-10700U DDR3-1334 (9-9-9-25 4-34-10-5) Memory Module : Nanya NT2GC64B88G0NF-CG 2GB DIMM DDR3 PC3-10700U DDR3-1334 (9-9-9-25 4-34-10-5) Video System Monitor/Panel : Dell Computer DELL E197FP (1600x1200, 19.1") Video Adapter : Standard VGA Graphics Adapter (6CU 6SP 850MHz/1.1GHz, Integrated Graphics) Graphics Processor Storage Devices Seagate ST500DM002-1BD142 (500.1GB, SATA600, 7200rpm, 16MB Cache) : 466GB (C:) (D:) Generic- Multi-Card (USB2) : N/A (F:) PLDS DVD+/-RW DH-16ACS H (68MB, SATA150, DVD+-RW, CD-RW, 2MB Cache) : 65MB (E:) Logical Storage Devices Hard Disk (C:) : 452GB (NTFS) @ Seagate ST500DM002-1BD142 (500.1GB, SATA600, 7200rpm, 16MB Cache) Recovery (D:) : 14GB (NTFS) @ Seagate ST500DM002-1BD142 (500.1GB, SATA600, 7200rpm, 16MB Cache) Removable Drive (F:) : N/A @ Generic- Multi-Card (USB2) Jan 27 2013 (E:) : 703MB (UDF) @ PLDS DVD+/-RW DH-16ACS H (68MB, SATA150, DVD+-RW, CD-RW, 2MB Cache) Peripherals LPC Hub Controller 1 : Dell H61 LPC Controller LPC Legacy Controller 1 : SMSC SCH5514D-NS Audio Device : Dell Cougar Point High Definition Audio Controller Disk Controller : Dell Cougar Point 4 port SATA IDE Controller Disk Controller : Dell Cougar Point 2 port SATA IDE Controller USB Controller 1 : Dell Cougar Point USB Enhanced Host Controller #2 USB Controller 2 : Dell Cougar Point USB Enhanced Host Controller #1 SMBus/i2c Controller 1 : Intel ICH SMBus Printers and Faxes Printer : Microsoft XPS Document Writer (600x600, Colour) Fax : Microsoft Shared Fax Driver (200x200) Peripherals Network Services Wireless Adapter : NETGEAR WG111v3 Wireless-G USB Adapter (802.11g (ERP), AES-CCMP, 54Mbps) Operating System Windows System : Microsoft Windows 7 Home 6.01.7601 (Service Pack 1) Platform Compliance : x64 Windows Experience Index Current System : 1.0 This is specifically concerning the hardware rather than any Pro Tools version (I purchased an Mbox that was not packaged with Pro Tools). Basically, the Mbox control panel shows that the hardware is not connected (in the bottom left corner) : ![]() However, the Mbox has M-Audio AV40 monitor speakers plugged into it, which do work (as in they're playing any audio coming from my computer). Why, then, does it say the hardware isn't connected (as well, it won't show up as an ASIO device in REAPER or any recording software I use. Again, this is an Avid Mbox 3 Mini. It's connected to a DELL through a USB port on the back. I believe there are six USB ports on this beast. Only four of them are occupied, if that's any help. They're arranged like 1 2 3 4 5 6 The Mbox is connected to number one, 2 is unused, 3 is unused, 4 is a wireless USB device, 5 is my keyboard and 6 is the mouse. I'm not sure how much of this information is necessary, but I'd rather give too much than not enough. I believe the USB cable running between the PC and Mbox is a monster cable. I've tried switching to all the different USB ports, including having nothing but the Mbox plugged in. I've tried reinstalling Windows, different PCs, reinstalling the Mbox drivers several times (I tried restarting after installing drivers, unplugging the Mbox, then plugging it back in), tried installing older drivers, etc). Thank you in advance for any help. Let me know if I left out any other necessary info. |
So, is there some way to actually contact Avid without having to pay them more money for a thing I already bought?
![]() Quote:
CP for MBox Mini has absolutely different UI: ![]() If your device is MBox Mini then install proper driver from here: http://avid.force.com/pkb/articles/e...nload/en374271 |
My mBox quit working randomly after I installed a set of Waves plug-ins. I updated the drivers for everything multiple times and went through many of the frustrations I've seen in this forum only too keep getting the unrecognized error.
The Solution for me: Use a powered USB hub to connect to mBox 3. Something like this one. I picked one up at my local memory express for $15. Hope that helps.
LIVE LOUD D.I.Y. DEAF - DEAFWISH |
Mbox Pro 3 blue light stays on but has the status of "Hardware not connected" | Focuret | FireWire & USB Audio Interfaces (Mac) | 1 | 01-15-2014 12:18 AM |
PT10/Mbox Mini "Unable to locate hardware..." | portrhombus | Windows | 3 | 12-21-2012 07:47 AM |
Error "unable to locate hardware. make sure your hardware is connected and turned on" | tmcgrechan | Windows | 2 | 10-06-2011 09:12 AM |
Yet ANOTHER Mbox 3 Mini "Unable to Locate Hardware" | Wayne_brady | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 12 | 06-14-2011 02:52 PM |
Mbox mini installation problem - "Hardware Not Found" | tinsoldierman | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 7 | 12-18-2010 03:06 AM |
