Old 06-25-2010, 06:46 AM
Kirby B. Kirby B. is offline
Default background services & system cache options changes?
Hi. When I select "Background Services" & "System Cache" options in My Computer / Properties / Advanced / Performance - Settings / Advanced, It sometimes changes to the "Programs" and "Programs" settings. No one else touches the computer. It has happened 4 times. Any ideas why it would do that?
Sandra, if you think that would help. Signature on the bottom says cs1, but it is cs2. Thanks..
SiSoftware Sandra
System
Host Name : LA-FORGE
User : KirbyBivans
Workgroup : WORKGROUP
Processor
Model : Intel(R) Core(TM)2 Quad CPU Q6600 @ 2.40GHz
Speed : 2.40GHz
Cores per Processor : 4 Unit(s)
Threads per Core : 1 Unit(s)
Type : Quad-Core
Internal Data Cache : 4x 32kB, Synchronous, Write-Thru, 8-way, 64 byte line size
L2 On-board Cache : 2x 4MB, ECC, Synchronous, ATC, 16-way, 64 byte line size, 2 threads sharing
System
System : System manufacturer P5K-E
Mainboard : ASUSTeK Computer INC. P5K-E
Bus(es) : ISA PCI PCIe IMB USB FireWire/1394 i2c/SMBus
Multi-Processor (MP) Support : No
Multi-Processor Advanced PIC (APIC) : Yes
System BIOS : American Megatrends Inc. 0603
Total Memory : 3.25GB DDR2
Chipset
Model : ASUS P35/G33/G31 Processor to I/O Controller
Front Side Bus Speed : 4x 267MHz (1.07GHz)
Total Memory : 11.13GB DDR2
Memory Bus Speed : 2x 401MHz (802MHz)
Video System
Adapter : NVIDIA GeForce 7300 GT (256MB, PCIe 1.00 x16, PS 3.0, VS 3.0)
Physical Storage Devices
WDC WD3200AAKS-00VYA0 320GB (SATA300, 3.5", 7200rpm, NCQ, 16MB Cache) : 298GB (C:) (D:)
WDC WD3200AAKS-00VYA0 320GB (SATA300, 3.5", 7200rpm, NCQ, 16MB Cache) : 298GB (E:) (F:) (G:)
LITE-ON DVDRW LH-20A1L (SATA150, DVD+-RW, CD-RW, 2MB Cache) : N/A (H:)
LITE-ON DVDRW LH-20A1L (SATA150, DVD+-RW, CD-RW, 2MB Cache) : N/A (I:)
Logical Storage Devices
WinXP (C:) : 87GB (NTFS) @ WDC WD3200AAKS-00VYA0 320GB (SATA300, 3.5", 7200rpm, NCQ, 16MB Cache)
Samples (D:) : 211GB (NTFS) @ WDC WD3200AAKS-00VYA0 320GB (SATA300, 3.5", 7200rpm, NCQ, 16MB Cache)
DOCUMENTS (E:) : 7GB (NTFS) @ WDC WD3200AAKS-00VYA0 320GB (SATA300, 3.5", 7200rpm, NCQ, 16MB Cache)
MUSIC (F:) : 227GB (NTFS) @ WDC WD3200AAKS-00VYA0 320GB (SATA300, 3.5", 7200rpm, NCQ, 16MB Cache)
ARCHIVES (G:) : 65GB (NTFS) @ WDC WD3200AAKS-00VYA0 320GB (SATA300, 3.5", 7200rpm, NCQ, 16MB Cache)
CD-ROM/DVD (H:) : N/A @ LITE-ON DVDRW LH-20A1L (SATA150, DVD+-RW, CD-RW, 2MB Cache)
CD-ROM/DVD (I:) : N/A @ LITE-ON DVDRW LH-20A1L (SATA150, DVD+-RW, CD-RW, 2MB Cache)
Peripherals
LPC Hub Controller 1 : ASUS (ICH9) LPC Interface Controller
LPC Hub Controller 2 : ASUS (ICH9) SMBus Controller
Audio Device : ASUS (ICH9) HD Audio Controller
Audio Codec : Analog Devices ??? (198B)
Serial Port(s) : 1
USB Controller 1 : ASUS (ICH9) USB Universal Host Controller
USB Controller 2 : ASUS (ICH9) USB Universal Host Controller
USB Controller 3 : ASUS (ICH9) USB Universal Host Controller
USB Controller 4 : ASUS (ICH9) USB2 Enhanced Host Controller
USB Controller 5 : ASUS (ICH9) USB Universal Host Controller
USB Controller 6 : ASUS (ICH9) USB Universal Host Controller
USB Controller 7 : ASUS (ICH9) USB Universal Host Controller
USB Controller 8 : ASUS (ICH9) USB2 Enhanced Host Controller
FireWire/1394 Controller 1 : Avlab Technology TSB43AB23 1394a-2000 OHCI PHY/link-layer Controller
System SMBus Controller 1 : Intel 801xx/63xx SMBus
Printers and Faxes
Printer : Microsoft XPS Document Writer (600x600, Colour)
Printer : Canon iP4300 (USB, Colour)
Scanners and Cameras
Camcorder : Logitech QuickCam Communicate STX #2 ()
Network Services
Network Adapter : Marvell Yukon 88E8056 PCI-E Gigabit Ethernet Controller - Packet Scheduler Miniport (Ethernet, 100Mbps)
Network Adapter : Bluetooth Device (Personal Area Network) #2
Power Management
Mains (AC) Line Status : On-Line
Operating System(s)
Windows System : Microsoft Windows XP (2002) Professional 5.01.2600 (Service Pack 3)
Platform Compliance : x86
Performance Tips
Tip 2546 : Large memory modules should be ECC/Parity.
Tip 2 : Double-click tip or press Enter while a tip is selected for more information about the tip.
Digi002R PT2018 Win 10
INTEL Core i7 930, 3.52 Ghz
GIGABYTE GA-X58A-UD3R
CORSAIR XMS3 12GB 1600Mhz
2 X WD 1TB Caviar Black 64 GB cache
MOTU Traveller PT2018
MacBook Pro Mojave
16GB DDR3
Old 07-12-2010, 10:44 AM
Default Re: background services & system cache options changes?
I found the solution, no thanks to any of you It was using Advanced Care System 3, which cleans up the C drive and looks for spyware etc. It changed the settings I mentioned above. I can still use the program, but afterwards I change the settings back right away.
Windows 7 Background services Caatalyst Pro Tools 10 2 08-31-2014 07:34 AM
Unnecessary XP background Services? Rowen Caplan 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 2 02-15-2011 12:14 PM
SO... Programs, System Cache or Background Services? GordonFreeman 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 3 05-24-2009 02:20 PM
Set Processor Scheduling to Background Services Fullsound Recording Pro Tools TDM Systems (Win) 4 08-08-2008 11:30 AM
BTD error and Disabling System Services question pedrohead 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 5 11-06-2003 10:03 AM
