Old 08-25-2009, 02:18 AM
d.f. d.f. is offline
Default External Clocking for Apogee - setting in PT?
I am running PT8 with Apogee AD 16X, 2xDA16x and Rosetta 800.
I want to clock the Apogees from an external source (Digital Audio Denmark ADDA2402)
Everything on Apogees set up correctly. Digital Audio Denmark set up correctly.
When PT is not booted up the Apooges see the DAD perfectly as Master Clock
- however -
when I boot up a PT session the Apogee automatically sets itself up to operate with her Internal clock.
Is there a setting on PT (in hardware set up or preferences) that I have to address in order to make it work?
Thanks, David.
Old 08-25-2009, 04:14 AM
BradLyons BradLyons is offline
Default Re: External Clocking for Apogee - setting in PT?
IF you go into hardware setup, make sure to look at the clock source and set to EXTERNAL WORD CLOCK.
Thank you,
Brad Lyons
www.howavl.com
Old 08-25-2009, 07:14 AM
hummerZ hummerZ is offline
Also, it sounds like you're feeding the Apogee WC from one of your digi interfaces. No need to loop sync.
Apogee AD-16X and HD I/O clocking issue track Pro Tools HDX & HD Native Systems (Mac) 7 04-18-2014 08:28 AM
Another Clocking question -- 192/SSL/Apogee greenwall Pro Tools TDM Systems (Mac) 3 07-05-2010 02:45 PM
Clocking to an Apogee Big Ben one 192 and a legacy alex3368 Pro Tools TDM Systems (Mac) 2 10-22-2006 01:52 PM
Clocking MIX system with Apogee AD-16 JNS Pro Tools TDM Systems (Mac) 4 04-04-2004 09:47 AM
Apogee Rosetta 800 clocking thin ice Pro Tools TDM Systems (Mac) 30 08-26-2003 09:18 AM
