Old 03-14-2004, 11:15 AM
Bambison Bambison is offline
Default 192 I/O won\'t sync to Aardsync II
Hi, I recently upgraded to Protools HD from a Mix+ system, including going from an 888/24 to 192 I/O. I'm trying to use my Aardsync II with the 192, but keep getting the following error when tryin got set the Aardsync as master clock:
"Clock Source is out of range and the peripherals have been reverted to Internal clock. Manually reselect the desired Clock Source after verifying the sync source."
I'm using BNC #1 output on the Aardsync with the internal jumper set to x256. I've also tried BNC #2 output (jumper set to x256) with the same results. Any help would be greatly appreciated.
BTW, I know some would suggest to ditch the Aardysync. But, I'd like to check it out for myself with the 192. It made a big diiference to me with the 888/24.
THX!!!
Old 03-14-2004, 11:26 AM
Tweakhead Tweakhead is offline
Default Re: 192 I/O won\'t sync to Aardsync II
Make sure you are not connecting Superclock to Wordclock or vice versa.
Old 03-14-2004, 11:37 AM
Nope, it's Superclock to Superclock. Thx, though.
Old 03-14-2004, 01:33 PM
One Track Music One Track Music is offline
The 192 & HD systems no longer use superclock, only workclock, so just set the jumpers at 1x and it should work fine.
Hope this helps,
Joel
www.joeldouek.com
"Show me your Pasodoble!"
Old 03-14-2004, 03:00 PM
Thanks, One Track. That did it. What I don't understand is why the 192 labelling reads, "EXT CLOCK 1x/256x."
Old 03-14-2004, 04:35 PM
jeremyroberts jeremyroberts is offline
Read THIS (from Aardvark Audio web site)
--Jeremy
Old 03-14-2004, 07:57 PM
That's if you want to hook up a legacy interface such as a 1622 or ADAT Bridge, which will need to get 256x clock from the 192.
www.joeldouek.com
Old 03-14-2004, 11:27 PM
Aah, got it. That makes sense. Thanx!
FS: AardSync II master sync generator €320 Baba Omar Jun Buy & Sell 2 11-06-2014 12:47 AM
FS: AardSync II master sync generator $275 jeremyroberts Buy & Sell 1 06-27-2012 05:35 PM
FS: Aardsync,MOTO MTP,VSD,Horita Sync Gen Captain Audio Buy & Sell 0 05-22-2012 10:19 AM
new sync IO vs aardsync II Chris Lambrechts Pro Tools TDM Systems (Mac) 1 01-31-2002 07:01 PM
3 Sync Boxes (Rosendahl / Aardsync / Genx) which one sounds best Daniel_Dettwiler Pro Tools TDM Systems (Mac) 5 11-20-2001 11:18 AM
