Old 08-05-2021, 10:26 PM
Samba Samba is offline
Default To Big Sur
I've been running Mojave and I'm considering Big Sur.
Given the wording on Avid's compatibility page doesn't make sense, I just want to ensure that the current Big Sur and current Pro Tools are compatable?
https://avid.secure.force.com/pkb/ar...ig-Sur-Support
"In the meantime, we recommend that you continue to use previously qualified operating systems until further notice."
This statement makes no sense considering there is nothing written before it to suggest it needs "in the meantime" and there's a compatibility grid underneath it
Old 08-06-2021, 12:35 AM
JFreak's Avatar
JFreak JFreak is online now
Default Re: To Big Sur
Big Sur is okay, just do a clean install to an empty storage.
Janne
Old 08-06-2021, 04:01 PM
DetroitT's Avatar
DetroitT DetroitT is offline
What’s you system?
Your Profile system seems out of date!
Old 08-06-2021, 05:02 PM
JFreak's Avatar
Yes it is, sorry about that. One week of testing M1
Janne
Old 08-10-2021, 05:47 PM
Originally Posted by DetroitT View Post
What’s you system?
Sorry I just updated my bio!
Mac OS 10.14.3
PT 2020.5.0
Old 08-10-2021, 06:22 PM
iigunzent iigunzent is offline
Mac OS 10.14.3
PT 2020.5.0
Unless you’re running 2021.7, or have the ability to upgrade to it, don’t do it. It’s not worth the headache. I’m using it right now, and randomly all my interfaces stopped coming up in the playback engine and i could only record through the pro tools aggregate…then randomly about an hour ago, pro tools crashed, i restart pro tools…boom. It works again like intended. It’s just happening at random at this point. No method or madness. Lol
Old 08-11-2021, 09:47 AM
This statement is intended for users on the newer Apple Silicon M1-based Macs (not Intel-based computers). While Protools 2021.6/7 is certified to run on Big Sur, there is a known issue (not yet coded) with the Video Engine in M1 Macs. Older (non certified for Big Sur) versions of Protools like 2021.3/2021.3.1 use the older Video Engine and do seem to function properly on M1 Macs.
So If you're on an Intel-based Mac, it is safe to upgrade to Big Sur.
Note: Some people have reported UI lagginess and repeated beachballs with Protools 2021.6/7 on multiple MacOS version but other do not experience this.
Obsidian Dragon
Mac Studio M1Max - 64GB
Old 08-19-2021, 02:40 AM
Dj-Ike Dj-Ike is offline
I just tested PT 2021.7 on Big Sur 11.5.2, using MBP I9. so far everything seems to be running fine. Didn't test the video though. Will do that from now.
Music is the Message
Old 08-19-2021, 02:45 AM
Another thing, I believe that some apps that run on Mojave, won't run on Big Sur, if I remember correctly. I kept an external Mojave drive just for that.
Old 08-19-2021, 02:47 AM
JFreak's Avatar
Catalina and 64bit only is the divider. Mist software that run on Catalina also run on BS, exceptions I have found are SoundToys AU and Sonnox Procodec
Janne
