Old 08-30-2007, 03:59 PM
GTBannah GTBannah is offline
Default MIDI Velocity
Hello, all,
The velocity in PT defaults to "80", as opposed to "100" in Sonar.
1) How does that compare with other DAWs?
2) Do you folk maintain the "80", or have you adjusted it to suit youw previous DAW(s)?
3) For "Strike!" users, how does it feel/work/sound at "80"?
Derrkins
GuyBarTola
PT 2018; Nuendo 8.?; Studio One 3; former Sonar and Sequoia user .... GENELEC 1031A, AVANTONE MIX CUBES (Active); Sibelius 7.0; Dorico; Mac Mini 2.6 GHz Core i7, OS X 10.12.2 Sierra; 16GB RAM; 480 GB System SSD; 1 TB 7200 rpm Audio; 3 TB samples; Roland A-800 Pro controller; GOOD BYE PEE SEA!!
Old 08-30-2007, 04:06 PM
mindnoise mindnoise is offline
Default Re: MIDI Velocity
HI,
1) 2) 3) you can adjust the default Midi Velocity value in the PT Preferences
regs
last: PT11.3.1
Old 08-31-2007, 03:42 AM
Ahhh, finally, a taker!
Thanx for the reply, man, but that wasn't what I wanted to know.
I'm wondering if the "80" setting works for anyone; and if there is a preference, one way or the other; if PT is the only DAW set at "80"; that sort of thing. Trivia, maybe?
Derrkins
GuyBarTola
Old 08-31-2007, 04:16 PM
GTBannah, Velocity values (Attack strength) adds many colorations, textures and even partials to a notes sound and it's this that should set the tone for what velocity value should be used.
Are you exporting SMF's into another application?
filosofem
Aaron Mulqueen - 001 HD Native
Old 09-01-2007, 05:22 PM
filosofem
Hey, thanx for the reply.
No, I'm not exporting. I'm coming to PT from a Cakewalk/SONAR bachground and made the observation that while Cakewalk defaults to 100, PT defaults to 80.
This is an un-official poll/survey of users' experiences with other DAWs and their preferences, if any.
Derrkins
GuyBarTola
Old 09-02-2007, 03:46 AM
zombie69 zombie69 is offline
Hello, all,
1: Well, I suppose that would depend on the patch/sample you are using on your synth/drum machine/plug in.
2: I don't pencil in notes, I play with feeling. It's called dynamics.
3: It feels the same, works the same, sounds different depending on how Strike is configured to play back multi samples.
What does it matter what the default value is if you can change it to what you like in the prefs? Midi velocity values go from 0 to 127. So 80 in one app is 80 in another. Same for 100 or whatever other value you like. Read up on midi a little more, and by the way, polls arent allowed here.
I wear the pants. (My wife picks them out)
Old 09-06-2007, 08:40 AM
....and by the way, polls arent allowed here.
Sorry, didn't know that.
Derrkins
GuyBarTola
MIDI Volume or Velocity Change results in part muted MIDI sound gavriil1 Pro Tools 10 2 07-01-2013 10:23 AM
Can't edit velocity only anymore? Notes copying with velocity data... kingtinker Pro Tools 10 5 11-12-2011 10:53 AM
MIDI Velocity GTBannah 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 0 08-30-2007 06:15 AM
midi velocity Jepse MIDI 0 12-30-2004 07:24 PM
Midi Velocity near 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 01-19-2004 12:13 AM
