Track I/O Will not reset
Ok I tried doing a search but when I do a search I get the message below so am posting a thread.
When I am at home I use an Apollo Twin and an Eleven Rack under Pro Tool Aggregate and have all my I/O labeled. When I disconnect my MacBook and open Pro Tools I use the N key and select Built In Output as my playback engine... I open an existing session and it opens fine. That all works; however; the stereo bus and master track I/O do not reset to Built In Output but instead show only the I/O options available when I have Pro Tools Aggregate set as my playback engine. I have selected the path in I/O setup and deleted it and selected Default and seen it rebuild to Built In Output several times and still the Master and Stereo tracks will not allow me to select Built In Output as an output path... Searched the manual and there is nothing in it on how to reset the track I/O itself. Any thoughts? Screenshots available if needed. |
Having to reset MIDI after creating new instrument track | rokvalek | Pro Tools 11 | 6 | 11-21-2016 08:06 AM |
audio track zoom reset? | Alex Rodriguez | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 6 | 06-29-2010 07:54 AM |
track automation reset ? | basslik | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 0 | 10-10-2009 09:01 PM |
Playlist # and track # reset request missing feature | Seti Orion | Pro Tools TDM Systems (Mac) | 3 | 11-26-2007 06:11 AM |
Can I easily reset an entire track's volume to zero? | yin7yang64 | Tips & Tricks | 3 | 03-07-2002 09:09 PM |
