Re: Kontakt 5 multiple outs crashing protools
This happens with many DAWs and in fact the fix is, TO use multiple instances so load is spread out amongst cores. Standalone kontakt multi processor preference is just for standalone, as kontakt itself says in brackets. i think the problem here is that too much is being asked of a single core. Humor me and try seperate instances and see if it fixes it. You also didn't say just how many instruments you are indeed running off the one kontakt multi, which would be helpful to know..
- Intel 14900K/NzXt Kraken Elite/64GB Kingston DDR5 6000 mhz (32x2)/ Asus Pro Art Z790/Asus 4090/Win 11 Pro 23H2/UAD Apollo 8 x2 w TBolt 3 card u/g/UAD Twin X. |
And when used with Pro Tools the word Standalone changes to AAX, check the engine when using as plugin version.
Dell XPS 8700. Intel Core i7-4770 CPU @ 3.40GHz. RAM: 16GB. Windows 10 Home x64. NVIDIA GeForce GTX 645. NI Komplete Audio 6. Pro Tools Software 2019 amagrasmusic.com |
that's quite exciting that it can access cpu outside the DAW. I'm going to do some tests now with it enabled and disabled.. what should happen when enabled, is that pro tool's own meter drops, and kontakt accesses cpu outside the DAW.. this is a good thing, having a separate process, cause no DAW can efficiently access 100% of the cpu anyway.. In pro tools i get up to about 400% usage out of a theoretical 800 before i can never go further. In logic about 550. Yet if i start some standalone kontakt even when the daw is being hammered like this, it works perfectly. :) So will be very interesting to do some multicore tests in kontakt, i think i'll tell it to use 4 threads, will see how we go, how far it can be pushed. Thanks for the cool info! PS i still believe the OP's issue is that the one instance of kontakt, although accessing separate cores itself, is still being stacked relatively on the one core in pro tools, which is why it's overloading. I see this in Logic all the time and when i switched to using say only 4 instruments of kontakt in one instance, and using many more multiple instances, all the load spread out evenly and play back without glitches. Not sure why Pro tools would be any different. I just don't see how pro tools can seperate different instruments of kontakt onto different cores, just because they are using different aux outputs. They are all still coming from the one instance of the plugin. Hey, i could be wrong, totally, but it's just how i've been taught that multi core in DAWs works.. that it's basically one core per instrument instance and all that follows it, effects etc, one per audio track and it's effects, including if it's routed to multiple further busses. This is how i've always understood it and my theory is, why not try it ? To the OP, what harm can it cause? But to answer this definitively, i am going to load kontakt myself now in PT, and load up 8 instruments on one instrument and send them each to their own aux in pro tools, and i am then going to load the same 8 instruments spread over 8 instances of kontakt, and see the results. I'll report back when i've done it.
#16
as i thought, multiple kontakt instances is balancing the load much better than 1 with multiple instruments. I'm convinced.
It's also interesting to see it grab CPU outside the DAW.. for heavy kontakt users, for 8 core machines I suggest 4 cores be the setting.. Even when pro tools was maxed out, i was able to still get more polyphony out of kontakt's that were already instantiated. I haven't tried instantiating fresh instances yet but will do so tomorrow, on a really hectic project. In any case, the solution to the OP's issue is to simply spread out everything via more kontakt instances. :) Cheers
#17
#18
One could of course *completely* remove kontakt from pro tools cpu space by using it via jbridge. Granted you would need blue cat patchwork to host it, and in a vst host like cubase using j bridge is way easier overall, but it is indeed a way to do it. You could literally use a lot of the available cpu outside of what pro tools is using. Just be prepared for noisy fans on an i7 laptop though lol. (j bridge can host 32 to 32, 32 to 64, or 64 to 64, and put the plugin in it's very own process space, each and every bridged plugin). It's an alternative to using VEPro whilst still keeping all the benefits of just a single pro tools project with load recall.
#19
#20
OP seems to have disappeared.
Kontakt & multiple outs (to PT aux inputs) | Jussi | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 6 | 07-29-2009 03:15 AM |
Multiple outs from KONTAKT | vicwind | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 3 | 03-13-2005 02:20 AM |
Kontakt multiple outs and PT 6.7.???? | Valeri | Pro Tools TDM Systems (Mac) | 4 | 11-03-2004 05:48 PM |
Kontakt Multiple outs into Protools | Tim R. | Pro Tools TDM Systems (Mac) | 22 | 12-08-2003 07:17 AM |
OSX Multiple Users Crashing ProTools | relaxo | Pro Tools TDM Systems (Mac) | 0 | 07-18-2003 06:26 AM |
