Go Back   Avid Pro Audio Community > Pro Tools Hardware > Pro Tools | MTRX & MTRX Studio
Old 07-22-2021, 04:43 PM
TrentWilliams TrentWilliams is offline
Default Dante Virtual Soundcard - MTRX Studio Setup
Hey all,
I'm just in the set-up stage of installing a new MTRX Studio, I'm trying to get system audio into the MTRX through Dante Virtual Soundcard but I'm having a hard time.
I think I have a clocking issue between DVS and the MTRX? DVS is showing muted in Dante Controller. I can't figure out where to go, or what to do. There's very limited information around.
Any help is appreciated,
Pro Tools 2024.3.0|Perpetual • MTRX Studio • HDX1 • Sync-X • S3 • Dock • Mac Mini 2018 - 3.2GHz i7 6-core macOS 13.6 • RAM 64GB DDR4 GPU AMD 6900XT 16GB • Monitor LG 32UL950-W
Old 07-22-2021, 05:06 PM
creativecontrol's Avatar
Default Re: Dante Virtual Soundcard - MTRX Studio Setup
If you are using a 10G Ethernet port in your 2018 Mac Mini this is likely the issue (known) with Dante Virtual Soundcard. Use an adapter like the Belkin:
https://www.apple.com/shop/product/H...hernet-adapter
That should sort it.
best,
Jeff
Jeff Komar
Solutions
S6 FAQ
MTRX FAQ
Old 07-22-2021, 05:11 PM
Ah excellent!
Thanks for the heads-up.
Will Eucon still work if it isn't connected to the switch?
Old 07-22-2021, 05:27 PM
It's actually preferred to separate your Dante (MTRX Studio + DVS) network from your EUCON network.
Jeff
Jeff Komar
Solutions
S6 FAQ
MTRX FAQ
Old 07-22-2021, 06:16 PM
Just went out and bought the adapter, plugged it in, and now DADman doesn't see the MTRX. I've tried a DHCP connection, and a static IP.
Old 07-22-2021, 06:22 PM
Make sure you see virtual LED life under System Preferences > Network for the Belkin. If a router, you should see green + an IP in the correct range. If no router, you should see amber + a 169 self assigned address range. If you've rejiggered everything and kept the MTRX ST on, you should power it off and then back on.
In DADman, access Settings > Device List to see the IP addresses of the detected MTRX devices. Right click on the detected device and access
Network Settings to ensure you have it configured the way you want - DHCP vs Manual.
Jeff
Jeff Komar
Solutions
S6 FAQ
MTRX FAQ
Old 07-22-2021, 06:32 PM
Thanks for your help with this Jeff, both DVS and DADman can now see the MTRX. However, DVS is still showing 'clock sync unlocked'.
Old 07-22-2021, 06:37 PM
Screenshots might help. Is the MTRX Studio set to be the leader clock? Dante Controller > Clock Status view.
DVS = 4.1.2.3
Dante Controller = 4.4.0.8
MTRX ST: cpufw = 1.0.3.2
DADman = 5.4.5.1
Jeff
Jeff Komar
Solutions
S6 FAQ
MTRX FAQ
Old 07-22-2021, 06:42 PM
Screenshots attached:
https://imgur.com/a/qXhzo1K
Old 07-22-2021, 06:48 PM
Which adapter are you using? That doesn't look anything like the Belkin which should be labeled Belkin (see below). Your issue is likely the adapter:
https://www.audinate.com/learning/fa...nte-controller
Here's what the Belkin USB-C should look like:
https://www.dropbox.com/s/7h4e6oebih...elkin.png?dl=0
Jeff
Jeff Komar
Solutions
S6 FAQ
MTRX FAQ
MTRX Studio and Dante Virtual Soundcard Ooptron Pro Tools | MTRX & MTRX Studio 13 07-14-2021 10:50 AM
MTRX Studio and Dante Virtual Soundcard Ooptron Pro Tools | MTRX & MTRX Studio 0 05-31-2021 02:36 AM
MTRX Studio and DANTE virtual sound card alvarodeiscar Pro Tools | MTRX & MTRX Studio 12 10-12-2020 01:57 PM
Dante Virtual Soundcard Mike Dy Digidesign Hardware & Software 12 08-21-2018 04:55 PM
Anyone using Dante Virtual Soundcard? Rockman413 Pro Tools 12 16 11-10-2017 04:26 AM
