Old 06-26-2009, 11:55 AM
ungratefuldead ungratefuldead is offline
Default Pro tools 8 access violation error
Hi guys,
I would like to know if somebody know a fix for the following issue.
Yesterday I installed altiverb on my machine and then the following error message pop up when pro tools is loading:
Could not complete your request because of access violation occurred,unable to read location 0X0A,9E5,A4F at address :0X78,145,74D in module msvcr80.dll
after that the system stuck and pro tools cannot be loaded.
so i uninstalled altiverb but the same think keep popping up does somebody know a fix for this?
I use PC windows xp 2 GB ram on 003 desk.
Thanks in advance.
Matt
Old 06-26-2009, 12:07 PM
rhythmtechnologies rhythmtechnologies is offline
Default Re: Pro tools 8 access violation error
what version of altiverb?
Old 06-26-2009, 12:12 PM
spkguitar's Avatar
First, I would contact AudioEase about that right away. That's a very expensive problem to have, and it honestly surprises me from one of their plugins.
Next, you are probably going to need to uninstall and re-install the Microsoft Visual C++ 2005 Redistributable.
And last, if that doesn't help, you will want to try to re-install Pro Tools.
Old 06-26-2009, 01:38 PM
Hi guys,
thanks for the replies, the version should be 5 not quite sure because I'm not in my studio right now.
I will try morrow what you suggest.
thanks again
Old 06-26-2009, 02:05 PM
spkguitar's Avatar
If you are using PT8, I'm pretty sure you need version 6.2.0 or above.
Old 06-26-2009, 02:23 PM
what he said ^^
Old 02-22-2010, 09:52 PM
rabbitsteven rabbitsteven is offline
Hey I'm getting the exact same error message and can find nothing about it strangely enough (except this post of course).
The only difference is, I'm not running any plug in's. I installed M Powered Pro Tools 8 for the first time and have not even had it up and running yet. I get that error message when I click on Pro Tools icon to open it.
I'm running a PC, 4Gb RAM, 1TB harddrive, Quad Core, Windows XP home, Service Pack 3. Should be more than enough to meet the requirements..
Any advice?
Thanks
Old 10-05-2010, 01:05 PM
bromston bromston is offline
hi. im having the same problem:
could not complete your request becaus access violation occured, unable to read location: 0X0DE75A4F at adress: 0x7814574d in module: MSVCR80.dll
have a mbox2 micro and i just installed pt but it wont open.
realy need som help with this
Old 10-24-2010, 08:43 AM
RobY_surf RobY_surf is offline
me too. help please..
Old 01-05-2011, 05:59 PM
Bobbarian Bobbarian is offline
Hi, make sure all your drivers are up to date. Also, try running the program as administrator.
I'm using Vista 32-bit SP2, and I get the same error if I don't choose, "Run as administrator." Right-click the shortcut icon and you should see it. Hope to hear some beautiful sounds in the future.
sound error on Pro Tools SE with a Fast Track C400 ; access violation dman813 Pro Tools SE and Essential (Mac) 1 12-28-2012 03:36 AM
access violation error and then pro tools crashes shp music 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 05-24-2012 12:48 PM
Access Violation error !!!!!!! Sherbert99 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 5 04-06-2006 09:50 PM
access violation error?? LadyElectrikStudios 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 8 07-24-2004 01:25 PM
Launching Pro Tools:Access violation and SynthCore error Coolin' 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 0 05-24-2002 04:30 PM
