Go Back   Avid Pro Audio Community > Legacy Products > Pro Tools 2020
Old 09-10-2020, 01:03 PM
lampmusic lampmusic is offline
Default Macbook Pro 16 Inch + Dock for PT
Sorry if this is the wrong section.
We switched to a new 16inch I9 MBP a few months ago and have been watching closely the performance with PT and a few other apps.
Of course the fans always raise when PT is loaded, but I am also noticing that while using an OWC usb-c dock the battery power starts to drop only while using PT.
I've done a little research on some mac support sites, and I understand there are docks that provide more power etc.
What is everyone else using?
At the office I'm using a USB - C m-audio interface and in the mixing suite I am using a tb2 Focusrite clarett 4 pre.
Running Pro Tools 2021.12
Main System 2020 M1 Macbook pro 13 inch / 16MB Ram / 1TB SSD / Big Sur
Future System 2021 14inch M1 Pro / 16MB Ram / 512 / Monterrey
Old 09-10-2020, 01:22 PM
Default Re: Macbook Pro 16 Inch + Dock for PT
I'm using an OWC 14-port Thunderbolt3 dock with a 2019 i9 MBP and haven't noticed any issues with battery or charging. There was an article out about making sure to charge MBPs from the right side: https://www.pro-tools-expert.com/pro...-in-the-studio
Also, I have found that using the free TurboBoostSwitcher to turn off Turbo Boost (overclocking), has helped to considerably reduce fan noise on my MacBook Pro. http://tbswitcher.rugarciap.com
Scott Gatteño
Old 09-10-2020, 02:02 PM
Is there any performance drop from turning off TB?
Old 09-10-2020, 02:34 PM
I don't use VI's, so I'm not usually pushing my system to the absolute limit. I'm guessing that there is a slight drop in performance when the temperature is low, but as soon as things start to heat up, the CPUs get throttled when TurboBoost is on, anyway. Best bet is to try it for yourself and see if it works for you. It's free and it's easy to just turn it off if it isn't working out.
Scott Gatteño
Old 09-11-2020, 01:44 AM
Originally Posted by originalscottyg View Post
I'm guessing that there is a slight drop in performance when the temperature is low, but as soon as things start to heat up, ...
Uh the CPUs love being cold. They don't need to warm up to perform, actually the opposite. Look at the overclocking folks playing with liquid nitrogen and other exotic coolers.
Old 09-11-2020, 06:45 AM
Yeah, badly worded on my part. I meant that when the CPU is cold, there is a boost in performance with TurboBoost on (slight drop in performance with TurboBoost switched off), but that they will quickly heat up that way and actually end up being underclocked by the system to cool them down.
Scott Gatteño
Old 09-12-2020, 08:25 PM
CarlNova CarlNova is offline
I have a similar set up; 2019 MBP16" (and a Mac LED Cinema Display) with OWC TB3 Dock. I also use Turbo Boost Switcher and it has helped with reducing CPU throttling. I have not experienced battery drop.
16 inch Macbook Pro - performance? lampmusic macOS 14 08-20-2020 11:09 AM
MacBook 13 inch, i7, 2.9 ghz, 8gb JustGotPaid macOS 4 01-17-2013 11:03 AM
15 or 17 inch New Macbook Pro? cary chilton macOS 14 03-23-2011 02:15 PM
Which is better? (New) MacBook Pro 15 inch or 17 inch Hookshot 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 13 07-21-2009 09:07 PM
They're Here! MacBook Pro - 17-inch coolcat 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 04-24-2006 02:20 PM
