Legacy 888 and ADC
I am trying out using an 888/24 on the legacy port of a 192. I set up an insert using the i/o of the 888 and delay compensation is showing only 6 samples of delay for the insert. This is obviously not right.
Does ADC work with legacy i/o? Thanks, Nic |
Re: Legacy 888 and ADC
Anyone have success using delay compensation on inserts with legacy interfaces?
Anyone?
I've never found any problems with using legacy interfaces with HD interfaces. And why is 6 samples for an insert wrong? It's TDM, not native.
A job's not done until it's ready, or the producer is breaking down the studio's door... |
Sorry, I should have specified that it's a hardware insert with da/ad through the 888/24.
I want to use this hardware insert on an aux doing parallel processing on vocals etc. So the delay compensation must be accurate. Basically, is automatic delay compensation supposed to work with hardware inserts using legacy interfaces? And if so, what am I doing wrong? Nic |
have you tried a test recording through the 888 (output to input no other gear)
and see what the real delay is so you can set it correctly
... "Fly High Freeee click psst tic tic tic click Bird Yeah!" - dave911 Thank you, Craig |
I guess that is what I'm going to have to do (set it manually). Drag, I was really hoping the automatic delay compensation would work with the Legacy 888 hardware insert scenario.
Once I calculate the latency at a given sample rate should that be constant, or might it change with differ buffer sizes etc.? Nic |
Legacy??? | suicune | Pro Tools TDM Systems (Mac) | 81 | 04-03-2013 05:12 PM |
Legacy 888 with HD I/O | James Drake | Pro Tools TDM Systems (Mac) | 2 | 05-24-2012 11:37 AM |
PT8 and Legacy | RussUK | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 4 | 10-13-2008 05:37 PM |
882/20 with 96 i/o legacy | PHead14006 | Pro Tools TDM Systems (Mac) | 3 | 11-27-2004 01:01 PM |
PT 6.0 on legacy Mac? | tubajay | Pro Tools TDM Systems (Mac) | 3 | 02-25-2003 04:16 PM |
