Old 05-30-2024, 12:17 AM
andyb-uk andyb-uk is offline
Default Pro Tools - SSL2 Interface - No Audio
Hi
Originally posted in the General Discussion area by mistake.
I am running Pro Tools 2024.3.1 on :
macOs Sonoma 14.5
M1 Max Macbook 32gb
I have an SSL2 interface and I am getting no audio input in Pro Tools.
I have got the correct interface set in the Playback Engine (SSL2)
In I/O i can see the correct Inputs
Input 1-2
Loopback L/R
Choosing an input on an audio track, and arming the track just has no input at all apart from a slight clicking of some form of audio, even with gain turned up on the interface.
I have checked that the SSL2 can input into the mac and inputs are showing on a audio monitor and I can record into something as simple as the Voice memo app.
Current audio input into the SSL2 is a line level instrument input
UPDATE:
Resolved. Mac Voice Isolation on the microphone input causing the issue.
Any ideas ?
Old 05-30-2024, 09:52 AM
DetroitT's Avatar
DetroitT DetroitT is offline
Default Re: Pro Tools - SSL2 Interface - No Audio
Hello. SSL-12 instrument is from front, line button off.
Also do you use the SSL 360 app?
Old 05-30-2024, 11:59 AM
THis is the SSL2 not the SSL-12
Old 05-30-2024, 01:06 PM
K Roche's Avatar
K Roche K Roche is offline
Originally Posted by andyb-uk View Post
Hi
macOs Sonoma 14.5
M1 Max Macbook 32gb
Input 1-2
Loopback L/R
Any ideas ?
Do have the SSL selected for input and output in Mac OS System Settings "Sound" and also in the Audio midi setup ?
System :
Studio - Avid Carbon interface , PT Studio 2024.10.2 Mid 2020 (intel) iMac 27" OS Sequoia 15.4
Mobile - 2021 14 " MBP M1 Pro PT Studio 2024.10 --Sequoia 15.4.1
Enjoy the Journey
.... Kev...
Old 05-30-2024, 02:53 PM
Hi
yes i have that selected
As mentioned i can record using something as basic as Voice memo
Old 05-30-2024, 10:13 PM
So the issue was the voice isolation mode enabled on the mac.
It made sense when I recorded a vocal and it worked to a degree, choppy and sounded like a gate was enabled.
Turned off voice isolation mode on the Mic Mode and all working now
Not my actual settings.
Pro Tools - SSL2 USB Interface andyb-uk General Discussion 1 05-29-2024 11:53 AM
Loopback in Protools with an SSL2 interface BWV846 Pro Tools | Intro Discussion 5 07-05-2023 02:45 PM
SSL2+ vs Mbox etc soundboy35 Third Party Interfaces 1 08-06-2022 09:30 AM
Hooking up SSL2 to ProTools pron022020 Pro Tools 12 12-24-2021 12:46 PM
Can Pro Tools Run Without An Audio Interface? JoeCoop Windows 5 09-20-2012 08:45 PM
