Yes deleting the paths and hitting Default. And importing IO Setting that were exported with a correct setup as well.
I’m able to upload an image from my phone (desktop version of this forum wouldn’t let me). As you can see there are only 2 hardware inputs, which is incorrect and wasn’t like this before. The outputs remain correct. |
![]() Quote:
I haven’t seen anything in MOTU Audio Setup about enabling/disabling - only Editing the Channel Names - but they all show up and named correctly. I just posted screenshots if you wanna check em out. |
Have you tried deleting prefs and I/O settings? Use Pete Gates’ utility or google instructions.
Yes. Both
![]() Quote:
So a test of what the driver is reporting vs. what Pro Tools is doing is in Audio MIDI Setup create an aggregate that just contains the MOTU interface and look at the subdevices section for that aggregate. You should see all the input and output ports and port names that the driver is reporting to CoreAudio. If you only see two inputs then the problem is in the driver or device -- try fully resetting the interface. If you see everything there you expect then it' a Pro Tools problem... and I'm stumped what that is. But one test I would do then is create a new admin user and try opening Pro Tools from that account. Don't open a session, just look at that interface in setup input I/O and see what it shows. (And yes even if you see the ports in the MOTU device in Audio Midi Setup I want you to create an aggregate and make sure they show up there). I expect MOTU drivers to be very well behaved but you can try to remove any potential source of problems. Don't have the interface configured as default sound output or system sound device and don't have it open in any other app. |
#16
Grasping at straws here. Any chance there’s an alternate 828 entry in the playback engine menu? Does the MOTU driver have its own prefs that can be trashed?
Do a hard boot? Shutdown, pull power cable, wait ten minutes, plug in power and boot up. This one has me stumped. If other software sees all the hardware paths, why doesn’t Pro Tools?
#17
+1 for Darryl’s last post.
#18
![]() Quote:
#19
![]() Quote:
Lots of software, including parts of Audio MIDI setup itself effectively caches what it knows about an interface. By creating a new aggregate you see exactly what the driver is reporting. You should try all things you can to reset the driver and interface... power cycle everything, do a factory reset on the interface (don't know what Motu gives the as options, etc.). Uninstall and reinstall the driver on the Mac--this could be a driver bug but is *very* unlikely.. the driver is responsible for reporting all this but it's hard to suddenly get that wrong, I would guess it's more likely to be the config/setup of the interface that is wrong or confused (which I thought James suggested earlier but now cant' find that). What exact driver version do you have installed on what exact macOS version and hardware? |
#20
![]() Quote:
MOTU driver is whatever the latest one is It may be difficult to do anything with the interface since it belongs to the studio I rent. It works just fine with the computer at the studio (which I’ve been using instead of my own machine lately). I like the idea mentioned earlier about creating a new user and opening a session to see if it’s tied to my user settings on my Mac or if it’s system wide. |
Wrong inputs and incorrect error about playback engine sample-rate support. | Mark Kieviet | Pro Tools 11 | 7 | 10-27-2016 02:11 PM |
Pro Tools-shortcuts on Windows 7 are incorrect or missing. Why/solution? | Lovah_lovah | Windows | 10 | 01-31-2011 03:02 AM |
Missing Inputs??? | kmusic | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 1 | 04-13-2010 01:29 AM |
inputs missing on 002 | irishjays | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 5 | 04-01-2009 03:41 PM |
Online registration detects incorrect hardware! | Henbane | Pro Tools M-Powered (Win) | 0 | 12-14-2006 10:00 AM |
