Go Back   Avid Pro Audio Community > Pro Tools Software > Pro Tools Sketch
Old 10-09-2023, 06:37 AM
JRVprotools JRVprotools is offline
Default Sketch Audio missing while installing Directory Not Found
Installing 2023.9 on windows machine. Apparently the intall can't find the sketch files directory even though it exists. Needed to click ignore about a hundred times to get throught the install.
Is this supposed to be like this? Hmmmmm
Old 10-17-2023, 01:57 PM
tope d's Avatar
tope d tope d is offline
Default Re: Sketch Audio missing while installing Directory Not Found
Might need to check some disk permissions. Check if your documents folder is set to read and write/Shared and not read only/private.
Thanks
-Tope
To create a support case with Avid Support, go to https://www.avid.com/learn-and-suppo...-music-support
www.topedomingo.com
Old 10-19-2023, 06:41 AM
marianna's Avatar
marianna marianna is offline
JRV.... let us know if the disk permissions helped with this.
Marianna
Marianna Montague
Sr. Dir. CX and Community | Customer Advocate
[email protected]
cell +1 (813) 493-6800
AOL IM avidmarianna
Twitter Avidmarianna
We're Avid. Learn more at www.avid.com
PtslCCppExport.h is missing (no file or directory) 0x07dc Pro Tools Scripting SDK Toolkit 1 05-11-2023 01:37 PM
Plugin directory security weakness - check your plugin directory permissions Darryl Ramm macOS 13 01-21-2020 04:54 AM
Directory not found or incomplete pathname (20) error when loading PT 11 thejonbee Pro Tools 11 1 06-01-2016 05:49 PM
master PT audio file directory? tragibigzanda 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 10-28-2009 01:11 PM
Normalized audio file in root directory avaldes 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 05-14-2006 08:14 AM
