Old 05-19-2002, 03:14 PM
matt vallo matt vallo is offline
Default AI3 drops out while recording
My Alesis AI3 has been dropping out all of the its channels that I am recording. It usually happens 25-45 minutes into continuos recording session. The other 8 channels from the digi001 will keep recording. The AI3 has power and the green signal indicators will still be flickering demonstrating I still have signals. If I turn the AI3’s power off and then on the signal is them picked up again. I purchased this unit new 6 months ago and have these problems for the last 2 months.
I have tried several setups and so far nothing has helped.
1. Used 1 optical connector from aI3 (out) to digi001 (in) ; set sync to optical.
2. Same set up as above but switched from 3ft Radio Shack to a 3ft Hosa optical cable.
3. Used 2 optical cables connecting aI3 (out) to digi001 (in) and the Digi (out) to the AI3’(in); set the sync to internal.
The protools sessions were recording in 24bit/48k to match up with the aI3’s specs. AI3’s optical out source was set to “optical in”
Am I doing something wrong?
Am missing something?
If anyone has had similar problems and solutions please do tell.
Thanks, Matt
PT drops recording issues Rockman413 Post - Surround - Video 11 05-04-2014 12:13 AM
Playback drops out. filosofem Virtual Instruments 1 07-23-2007 09:31 PM
About 2 minutes into recording audio drops out? smattsav 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 10-15-2004 01:26 PM
Bottom drops out! Extreme Mixing Pro Tools TDM Systems (Mac) 1 11-06-2003 01:10 AM
Recording Punch: Audio on other tracks drops out! SteveU 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 05-15-2002 02:47 PM
