Old 05-13-2024, 07:33 PM
npapaleo npapaleo is offline
Default Discrepencies between atmos internal renderer and Dolby external renderer
So I'm discovering discrepancies between the Internal and External renderer and wondering if it's a bug or a "feature". My main gig is mixing video game cinematics. All our cinematics get mixed in Atmos, and having the internal renderer is a game changer regarding efficiency and workflow. However, instead of delivering an ADM or Atmos master file, I provide a 7.1.4 channel-based WAV as the final deliverable. This 7.1.4 file is then ingested in Wwise for use in-game. After switching to the internal renderer for the first time using (2023.12 initially and now on 2024.3) and exporting a 7.1.4 re-renderer directly from the PT renderer, the team on the game side of things said the mix sounded "off." I wasn't able to get anything more specific than that. However, when I exported an ADM from PT and used that to export a 7.1.4 re-render from the Dolby external renderer, I was told this played back perfectly. Has anyone else experienced anything similar to this or am I on an island as I don't deliver an ADM?
Another thing I noticed. When exporting a 7.1.4 re-render from Pro Tools and reimporting in PT, the file ingests perfectly and is labeled as a 7.1.4 interleaved file. When ingesting into PT a 7.1.4 re-render from Dolby Renderer, PT sees it as a 12-channel mult-mono with each file labeled 1-12 instead of L, R, C, etc. Is this behavior correct?
MacBook Pro M2 12core 64GB RAM
MacOs 13.6.6
Pro Tools Ultimate 2024.3
Grace m908
Old 05-14-2024, 07:51 AM
tope d's Avatar
tope d tope d is online now
Default Re: Discrepencies between atmos internal renderer and Dolby external renderer
MacOs 13.6.6
Grace m908
Hi There,
I tried to create a case but I can't find any Avid Account associated with the Email you used here at the DUC. Can you update your Email or PM me your registered Email?
-Tope
To create a support case with Avid Support, go to https://www.avid.com/learn-and-suppo...-music-support
www.topedomingo.com
Old 05-14-2024, 11:31 AM
I do have an account with the email used here. I wasn't able to send you a PM as it says you don't accept PMs. Perhaps you could try sending me a PM?
Originally Posted by tope d View Post
Hi There,
Old 05-14-2024, 11:34 AM
marianna's Avatar
marianna marianna is offline
HI there.....
I found your MyAvid account and I am creating the case now..... Case # 04803075
Stand by... :)
Marianna
p.s. I miss Long Beach , Seal Beach etc. - use to live in Huntington right across from the pier on 8th st. Good ole days......
Marianna Montague
Sr. Dir. CX and Community | Customer Advocate
[email protected]
cell +1 (813) 493-6800
AOL IM avidmarianna
Twitter Avidmarianna
We're Avid. Learn more at www.avid.com
Old 05-14-2024, 12:58 PM
kosmokrator kosmokrator is offline
Sadly I think you might be on a quite deserted island delivering channel based immersive masters.
Did you ever try to import both 7.1.4 re-renders back into PT and do a phase flip on one?
Old 05-14-2024, 11:37 PM
Yeah, that's what I figured. I'm considering just doing a channel-based 7.1.4 mix and avoiding the renderer altogether.
To answer your question, yes, I have imported them back into PT, and they do not null. I've gone channel by channel as well as compared full mixes.
HTML code is On
Delay Compensation issues internal Dolby Atmos Renderer niviro Pro Tools 3 08-26-2024 08:09 PM
Dolby Atmos Internal Renderer Incorrect Playback on Monitors Syncbox Post Pro Tools 3 01-04-2024 07:25 AM
Printing internal Dolby Atmos Renderer christian kuntner Pro Tools 3 12-21-2023 01:36 AM
Pro Tools 2023.12 Internal Dolby Atmos Renderer Questions and Setup Update bolisound Avid Pro Mixing General Discussion 3 12-15-2023 08:51 PM
Dolby Atmos Renderer v5.2 dominicperry Pro Tools 4 12-15-2023 06:54 PM
