Old 07-23-2007, 03:18 AM
Default Playback drops out.
Greetings All/Digi
I've just encountered a problem where playback drops out with one particular Strike Preset Setting - RnB. The session's tempo is set at 100 1/4 Notes but Strike's Speed is set to Half. Structure is the only other VI in the session with five Patches and multiple channel assignments.
Upon begining playback the session plays back as it should, however, after the playback cursor triggers the first Chorus Pattern after the Intro playback stops and gives a loud digital click sound. Press playback again and although the session plays back, there isn't any audio.
Sometimes, changing the H/W Buffer Size brings the sessions audio back, after this digital click, but not always. I'd like to also point out that the audio drops out at the same location in the session every time, first Chorus Pattern (D3 Chorus B) after the Intro with a digital click sound.
Ummm... load another Strike Preset Setting with the same triggers in place, tempo and Strike Speed setting and the session plays back fine. It only seems to be Preset Setting RnB.
Strike's Configuration Content Size was set to 250 MB and is now at Default. Over Sampling is On. 32 Voices, Beat Sync - Beat, PCG - Off, Pattern Retrigger - Off, Fill Triggering - A.S.A.P., Crash - On and Pause Mode Toggle.
This also happens to a newly created session with the Strike session data imported.
There's not much in the General Troubleshooting thread that applies here, Prefs have been deleted. Database hasn't been deleted.
This isn't a hardware problem, as I said, load another Strike Preset Setting and she's away, but just in case.
ASUS K8N-DL
Quad AMD Opteron 265
Radeon X550
SIIG PCI IEEE 1394
4G RAM Corsair
WD SATA 36 G Raptor
WD SATA 74 G Raptor
XP Pro SP2
Mbox 2 Pro
LE 7.3.1 cs3
filosofem
Aaron Mulqueen - 001 HD Native
Old 07-23-2007, 09:31 PM
Default Re: Playback drops out.
A full re-install of Strike fixed this.
filosofem
Audio drops during playback Skumbat Windows 14 11-17-2012 10:59 AM
Output Level on one channel drops on 1st seconds of playback Imgoinmad macOS 15 12-02-2011 10:23 AM
HDx on Profile. 1 channel drops out on playback InjuredEar VENUE Live Sound Systems 6 03-24-2011 05:38 PM
Down arrow no longer drops cursor during playback... RobbaDobba 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 11-21-2007 11:15 AM
playback skipping & sound drops in and out on rec. simplescott01 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 07-02-2006 04:06 PM
