System Freezes when calculating overviews
I'm having a problem I just can't solve.
When recording in 88.2 kHz, sometimes the system freezes completely when calculating the overviews after a record pass. I have to press the power button to shut down the computer. Nothing is written in the system logs. It happens 1 - 2 times a day. Never had a problem when running 44.1 or 48 kHz. The recordings are around 3-5 min. long. The system is a Powermac G5 DP 2 gHz w/ 3 GB ram running 10.5.8. The Pro Tools system is a HD3 v. 8.0.1cs2 I have been thinking it could be a RAM issue, but I have tried to run an Apple hardware test, which passed with no errors. Any idea what the problem is?
System: PT HD3 8.0.1 192 i/o. OS X 10.5.8 PPC. |
Re: System Freezes when calculating overviews
Does this happen on every session or just the one? What hard drive are you using?
It happens on every session. Mainly I'm recording to an external FW800 drive. But I also tried using our internal audio drive. It makes no difference.
How much ram do you have? At 88.2k you need double of everything from a 48k session. Chris
I got 3GB ram.
But in a session that has no more than 26 tracks and no plugins etc. shouldn't do that. I can run 130+ track sessions in 44.1 kHz. (I have opened big pre-PT8 session that also needed re-calculation). And it definitely shouldn't freeze the whole computer (screen freeze. mouse & keyboard doesn't respond)
Hi, could be a faulty ram stick! can you try by rotating the ram and using 2gig to test, keep 1gig out when checking then swap around etc. Have you checked all plugins are up to date and compatible! Run this app and paste the list here... http://www.sendspace.com/pro/dl/9xyx8w Chris
Hi Chris.
Thanks for your help. i will try to rotate the RAM when I get back to the studio Monday. I'll report back
Calculating Overviews p**ing me off! | KMcK | macOS | 10 | 09-02-2013 05:39 PM |
PT10 : Calculating Overviews | midnightrambler | Pro Tools HDX & HD Native Systems (Mac) | 3 | 08-10-2012 06:56 AM |
when I open a PT9 HD session in PT10HD - why is it calculating overviews? | MixerGuy | macOS | 3 | 12-23-2011 06:28 AM |
pt8 calculating overviews - backup nightmare | sammyfarr | Pro Tools TDM Systems (Mac) | 11 | 02-18-2009 05:25 PM |
Calculating overviews when loading | stevegalante | Pro Tools TDM Systems (Mac) | 1 | 04-22-2000 09:32 AM |
