Go Back   Avid Pro Audio Community > Pro Tools Hardware > Pro Tools | MTRX & MTRX Studio
  #51
Old 06-29-2021, 09:15 PM
Goombot Goombot is offline
Default Re: MTRX Studio HDX and Dolby Atmos Production Suite
I already ordered it. ha. Yes, I'm hoping that will solve some of this mess.
  #52
Old 06-29-2021, 09:20 PM
I would be fairly confident it will, unless you have something funky going on in your network. Remind me, which switch are you using? Does it meet the Audinate requirements?
  • For channel counts of 32 or more, Gigabit switches are essential
  • Quality of Service (QoS) with 4 queues
  • Diffserv (DSCP) QoS, with strict priority
  • Energy Efficient Ethernet disabled
https://lukehoward.com/
  #53
Old 06-29-2021, 09:24 PM
Right. This switch...
https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
It's qualified. Although I'm definitely having some sort of network issues because my EuControl is not working.
  #54
Old 06-29-2021, 10:13 PM
LDS LDS is offline
What is the latency of your MTRX studio set to in DADman? It is in the Dante tab with the rest of the sync settings.
  #55
Old 06-29-2021, 10:17 PM
Good idea – could be worth changing to its maximum setting (5ms). If I understand it correctly, Dante latency is set by the receiver but cannot be greater than the minimum supported latency of the sender (which is 4ms for DVS).
  #56
Old 06-29-2021, 10:20 PM
I had the max for everything. I believe 12 for the Mac, 5 for MTRX.
  #57
Old 06-29-2021, 10:23 PM
I also now got these…
File Type: png F2D84649-7FAF-4F10-9B11-13E5C84BF600.png (23.8 KB, 0 views)
File Type: jpg 80757052-8CDA-45B3-8CE5-8DA9CA636DC0.jpg (12.5 KB, 0 views)
  #58
Old 06-29-2021, 11:13 PM
LDS LDS is offline
Try setting your MTRX studio to 1ms, purely as a test. I’m running 1000us and 10ms on DVS with no latency issues at all.
Though it seems like your setup might be having some bigger issues than just Dante latency. Swapping that Belkin USB adapter out is something I would really try, even if it is just to rule it out as the cause of your headaches.
  #59
Old 06-30-2021, 01:16 AM
I’ve never seen the first error but, check you’re on the most recent DVS re: the second.
  #60
Old 06-30-2021, 01:20 AM
uptheoctave uptheoctave is offline
I have the same switch (3 of them actually).
So it being qualified is good.
Is it configured properly?
Are you using DHCP?
What is serving DHCP to the network?
Is it your router?
I've found several problems coming from improperly configured routers feeding DHCP to the network via the switch.
There is about 100 different things I could ask you though and still not get the totality of the network like it would be if I was there.
If you are having networking issues then it might be best to start again with your network.
FIrst reset the network devices to their standard config and reconfigure the network from scratch.
Just start with the MTRX Studio and the Mac on the network plus the switch and whatever is serving DHCP to the network.
And I MEAN nothing else, if you have two network ports on your Mac, just use one.
Nothing else on it at all.
Then progressively add devices until it falls over.
FS: Dolby Atmos Production Suite License LDS Buy & Sell 1 10-20-2020 02:37 PM
MTRX Studio + Atmos Prod Suite ViciousLullabyz Post - Surround - Video 8 07-08-2020 03:45 PM
Dolby Atmos Production Suite 3.02 download LDS Post - Surround - Video 3 08-20-2019 07:03 AM
Dolby Atmos Production Suite garnoil Post - Surround - Video 2 03-13-2019 08:34 AM
Dolby Atmos Production Suite subhuffer Post - Surround - Video 20 03-10-2019 06:40 AM
