Send audio tracks to reason in rewire
Hi!
I just can't find a way to go through this. I would like to send an audio track from Pro Tools, to Reason, while in rewire mode, process in reason, then get Reason output back into Pro Tools. I'm using reason to process voices and SFX, and I have Reason 10, can't afford Reason rack right now. Is there any way that I can loopback from Pro Tools to Reason without exporting and importing files? Thanks §everyone.
udbu SOUND |
Re: Send audio tracks to reason in rewire
Hi as far as i know you can't do that native. What comes to my mind is to use a 3rd app driver like loopback audio. I think that should do the trick with limitations in reason stand alone.
Mac M1 Studio Ultra - Sonoma Beta OS Avid Carbon Interface Protools Ultimate |
Hi! Thanks for the input, do you know if that would be possible with Reason 11 or Reason +. I may have access to a trial, then when more projects comes I would buy the new version.
udbu SOUND |
As mentioned above, you can’t do that via ReWire in Reason. Whilst ReWire technically can move audio and MIDI in both directions, the software needs to be able to work as either a slave or master. In this case, PT only works as a master and Reason as a slave.
Trying a Loopback software may work, but honestly, now that Reason is available as a plugin inside your DAW, that is the way you should be going. It will do exactly what you’re after. You say you can’t afford it right now. Why not rent it for the next few months until you save up enough to upgrade? Reason is now available as a subscription, so that should tie you over until you have enough funds to pay for the upgrade. Might even be able to time it with a sale. Sent from my iPhone using Tapatalk |
The only way to do it is using loop back audio, if your interface allows it. But, to make that work, you can't be in Rewire mode. Instead you need to open Reason first, then Pro Tools. Then, you use loop back audio to send the audio to Reason and back into Pro Tools. Its convoluted, and takes a bit of setting up, and it creates latency.
If you can upgrade to PT 11, then you can simply install the Rack on any PT track and use whatever REason fx you wish. Much easier and cleaner.
"Never believe anything you hear in a song." Tyrion Lannister, Game of Thrones Owner: Dragon Rock Productions LLC |
You mean upgrade to Reason 11 right? You wrote PT11. Sent from my iPhone using Tapatalk |
Yes, I meant Reason 11. Hey, it was 4am and I was having a sleepless night!
Every night of my life. Sent from my iPhone using Tapatalk |
Reason Rewire - How to route audio into separate PT tracks? | Poparad | Pro Tools 12 | 2 | 03-09-2017 07:52 AM |
PT LE 6.4 - ReWire / Reason / Stereo Tracks | g00db33r | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 1 | 06-17-2008 10:55 PM |
copy a send (w/send level intact) from 1 to 30 audio tracks? | MixerGuy | Pro Tools TDM Systems (Mac) | 3 | 12-30-2007 03:20 PM |
Cant record reason tracks via rewire | justrob | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 6 | 06-10-2004 04:40 PM |
how to reocord tracks from reason thru rewire? | sinnagod | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 3 | 05-29-2004 07:46 PM |
