Old 09-11-2021, 07:57 AM
ballandbiscuit ballandbiscuit is offline
Default Control app soft keys not working as expected
Hi everyone,
I've been trying to create some custom soft keys for a tablet running the Control app, without much luck so far.
One of the workflows I'm trying to automate is printing my final mix. The intended sequence of commands would be: Scroll to the "print" track in the session, select it and the next track down, arm them both, and record.
I've got the following programmed so far:
Key (Alt) (Cmd) f
Key print
Key \n
Key (Shift) ;
The soft key works as intended with the first three lines, but if I add anything after that, the text doesn't get entered correctly into the "Scroll To Track" dialog. I've also tried using the Eucon command for Scroll To Track, but this was even more unpredictable, with the text being entered correctly about half the time.
Is this expected behaviour, or a bug? I'd be grateful if anyone could point out a glaring user error, or suggest a workaround.
Many thanks.
Just in case my sig's out of date:
Mac Mini M1 16GB; macOS 11.5.2; Pro Tools Ultimate 2021.7.0; Eucon 4.7.9.7
Old 09-13-2021, 09:25 AM
EddieJones's Avatar
Default Re: Control app soft keys not working as expected
This is possibly due to timing. We want to add a better way to put a delay in the macros.
Old 09-13-2021, 09:27 AM
Thanks Eddie - glad to know this issue is on your radar.
I’d be curious to hear from anyone who’s successfully programming macros to the soft keys.
S6 soft keys not working reliably Steven1145 Avid S4/S6 2 06-11-2020 11:58 AM
20.1.0 automation mode soft keys still not working bartosz idzi Artist Series 6 02-19-2020 10:37 AM
S6 Master/Automation Soft Keys Not Working MoreMe Avid S4/S6 3 03-16-2018 11:08 AM
New Tracks Soft Keys not Working zillmer Avid S1, S3, Dock and Control App 2 02-08-2017 07:00 PM
Soft Keys 9-16 not working. J-S-Q Avid S1, S3, Dock and Control App 2 05-19-2015 12:51 AM
