Re: Is there a way to expand HD Omni to have 13 channels (7.2.4) for Dolby Atmos mixi
So adding a 192 with my HD Omni for 16 channels would work then, yea? But then I would also need a whole monitor controller no?
MacBook Pro Touch Bar (15-inch, 2016 2016), 2.9 GHz Intel Core i7, 16 GB 2133 MHz LPDDR3, Radeon Pro 460 4096 MB Intel HD Graphics 530 1536 MB | macOS Monterey | Avid HD Native Thunderbolt | Avid HD Omni | Pro Tools Ultimate | Avid Artist Control | Avid Artist Mix | Avid Artist Transport | Genelec 8351b Monitors | Genelec 7360A Subwoofer x2 | Slate Digital VMS Virtual Microphone |
If you have enough outputs, your only headache (after making the connections) is wether you want to control volume by asjusting Master Fader or turning a knob on a physical device.
Artist Control and Artist Mix work. You don’t need an extra monitor controller. If a 192 helps to create a controllable 7.2.4 monitor path I don’t know.
Mac Pro 2010 3.66 GHz six Cores, HD Native, 192 I/O, Avid Dock, Artist Mix and Pro Tools Ultimate Mac mini 2018 i5 64 GB RAM, RME Fireface, Pro Tools 2021, Euphonix MC Control MacBook Air 2020 (M1) 16 GB RAM, 1 TB SSD, Zoom U-44 and Pro Tools Ultimate |
As Mark says, The MTRX Studio is the best way to go for you IMHO, It's an I/O for Pro Tools and a monitor controller at the same time, like the Omni on steroids.
The monitoring features on the MTRX Studio, volume/Sources/Dim/Independent speaker mute and solo etc, can be controlled by the free PT Control app on your IPad. I found it quite a steep learning curve myself. I didn't find the way it operates very intuitive, but on the plus side it's capable of being setup many different ways and once you have it set the way that works for you, it's great. Also there are lots of threads on here and many videos available to help you get it working the way you need. You can get the right number of outputs with a 192 or 8x8x8, but you would still need another atmos capable monitoring unit to control speaker mutes and solos etc, to use it effectively.
Mac Pro 7,1 16 core, OSX 12.7.3, HD-Native TB, Trinnov MC, MTRX Studio, 2xRME ADA-4, Sync HD, AJA IO XT, Avid Dock, Avid S1, PT Control, Soundflow, PT 2023.12 |
Another plus for the MTRX Studio is the built in SPQ card which has speaker EQs and Delays to let you calibrate your speakers and adjust delays to compensate for speaker positioning etc. (i.e. you side surrounds are closer to you than your front speakers, or your front LCR speakers are in a straight line and the center channels needs a small delay to arrive at the mix position at the same time as L & R).
Scott Gatteño |
#16
#17
#18
Scott Gatteño |
#19
https://www.pro-tools-expert.com/hom...room-eq-wizard
Jan Lykke Business Development Manager DAD - Digital Audio Denmark |
#20
I'll be doing this soon, when my room is finished being built, but I will be working with the acoustician/designer, who will measure the room with his system and make the adjustments in SPQ.
Scott Gatteño |
Dolby Atmos Spatial Audio Mixing on PC? | EliLitwin | Windows | 3 | 11-27-2021 01:39 AM |
HDX and Dolby Atmos | ViciousLullabyz | Pro Tools HDX & HD Native Systems (Mac) | 7 | 08-13-2021 06:29 AM |
Mixing in Surround and Dolby Atmos | Sreejesh | Tips & Tricks | 6 | 02-25-2017 12:55 PM |
Dolby Atmos | subwoof | Post - Surround - Video | 3 | 09-11-2014 12:10 AM |
Dolby Atmos | peter5992 | Post - Surround - Video | 20 | 10-29-2012 01:51 PM |
