digi midi unit latency
Hello using Digi midi with DP for programming. The latency between playing and hearing is rediculisly long. i have an old Midisport 8x8 but don't want to have to rewire everything. Any reason for this? do any users of logic suffer this?
cheers |
Re: digi midi unit latency
What type of synth are you triggering? How are you monitoring it - through a mixer or through Pro Tools?
If you record MIDI data on a track and play it back, does it play back in time properly? |
remove all plugins from the instrument track. You are probably using a high latency plug.
--Jeremy |
Hello i am using waldorf rack attack, nord electro, xv-50-80 mostly. i will try and record and see if there is much delay on that side. The other thing is when i use the indigo plugin that doesn't seem so bad it seems to be on the way backout to hardware. Will try that just now and post in a few minutes
thanks for getting back |
oh sorry and i am monitoring through a mixer.
Hello again. When i record enable my midi track to my xv50-80 and play a note i probably get around half a second of latency )(approx, not quite sure how to mesure that) playing in real time. However after recording or drawing in notes, during play back this latency is significantly reduced to the usual 200 odd samples.
Thanking you. |
10.4.11/LE 7.4/Digi 002 -- MIDI Latency and other Issues. | JayCRB | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 1 | 02-19-2008 06:02 PM |
Digi MIDI I/O unit sometimes goes offline | delgadil | MIDI | 1 | 09-10-2007 09:58 AM |
Digi 002 Midi Latency Anyone? | weedrock | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 2 | 11-12-2003 03:42 AM |
digi 002 - midi to audio latency | bustromo | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 7 | 03-24-2003 09:39 AM |
digi 002 audio to midi latency | pinky | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 0 | 03-18-2003 08:37 AM |
