Old 12-26-2018, 05:22 AM
Default Bluray in a 2012 MacPro cheesegrater
Been looking to add a Bluray burner/reader to my 2012 MacPro cheesegrater running OSX 10.12.6. I want it not so much for storage of files but to play movies on. Now I've done the research and know that for some odd reason Apple doesn't have native support for this. In the research I've also found that to be able to play Bluray movies you need auxiliary s/w to do so.
From that research I found that there appears to be just one program
https://www.macblurayplayer.com/
that will work but it needs to be connected to the net to decrypt the video. Thing is I like to keep my daw machine off the net as much as possible. I've also come across numerous reviews of said s/w and it appears to not be all that stable. And after reading the FAQ for the s/w it looks like something I can't say here but contains the word 'cluster'.
It seems the easiest part is installing the bluray drive is the easy part. Getting it work work as a movie player seems to be the issue. Has anyone done this and if so how'd it work for you (or not)? What s/w did you use to get it to work?
Or am I on a fool's errand doing this?
The whole reason is so I don't have another piece of h/w floating around the place which is already cramped. If that is my only choice I've found a couple of external players that would normally go with one's living room a/c setup that are all-region players. Why is all-region a thought you ask? Over the past year or so I've gotten several dvd's that were mismarked as region 1 but were anything but region 1. And several dvd's I'd like don't come in region 1.
Open to options if someone has a good one.
Old 01-06-2019, 10:04 PM
cwsand's Avatar
cwsand cwsand is offline
Default Re: Bluray in a 2012 MacPro cheesegrater
Blu-ray Player Pro (what you have listed) is what I use. I'm not sure, but I think the Pro version doesn't require an internet connection - I've never had any issues with it but I only own 1 Blu-ray set - the Beatles 1. Blu-ray Player Pro plays it fine.
Help Us Help You
Chris
Focusrite Liquid Saffire 56
TCE Studio Konnekt 48
PreSonus Digimax LT
macOS Catalina 10.15.7
Pro Tools HD 2020.12.0
Old 01-07-2019, 05:16 AM
I've quite a few BluRay dvd's so it's not a trivial deal for me. On their FAQ page there's a number of things that point to having to have an internet connection. Just one is in the video & audio section where someone asks about why the video freezes 4 to 5 seconds when trying to play a BluRay movie. Basically the answer is the program needs 4 to 5 seconds to remove the Bluray protection with the network and as of now their servers are only in the US. There's another in the Performance section about failing to connect to verification server.
What's confusing is that further down in an answer to another question they say the Pro version doesn't need internet connection now. In the above items I mentioned they make no mention of Pro versus regular versions.
Also what I can't find is if they only play region 1/A dvd's. In my research for multi-region players I found that no company directly sells them but rather they are unlocked by a third party - that's the answer I got from B&H. And then you only get a warranty from the seller in B&H's case that's 90 days and not the manufacturer's warranty.
Compatible LD DVD/Bluray drives for Mac Pro Alécio Costa Pro Tools TDM Systems (Mac) 0 04-10-2013 05:23 PM
BluRay in NYC stormmusic Post - Surround - Video 9 08-30-2010 08:04 PM
.DTS-HD to bluray? skip65 Post - Surround - Video 7 08-25-2010 01:36 AM
7.1 PCM Audio to BluRay Disc skip65 Post - Surround - Video 10 06-09-2010 01:12 AM
7.1 with CPTK to bluray skip65 Post - Surround - Video 5 05-21-2010 03:13 AM
