Old 03-11-2018, 06:44 AM
jjsoundoc jjsoundoc is offline
Default Keeping Control Active
After upgrading, I'm finding that going away from PT to a program like RX6, causes Control to become inactive.
When I come back to PT, I need to launch my user soft keys again.
Is there a way around this?
Old 03-11-2018, 09:03 AM
Default Re: Keeping Control Active
Sorry, should have pointed out that i'm using Artist Mix with the ipad app.
Old 03-11-2018, 12:00 PM
reichman's Avatar
reichman reichman is offline
Go to EuControl Settings/Assign/Lock to Application, and choose PT.
If that doesn't help, reinstall EuCon. Good luck!
Nathaniel Reichman
Producer/Re-recording Mixer - New York
Nathaniel Reichman | IMDB | LinkedIn
Old 03-11-2018, 01:37 PM
BScout BScout is offline
In addition to what @reichman posted (which is the correct way to keep the Eucon devices locked to Pro Tools when switching apps), if you are needing to re-establish soft keys, I'd go and check your user templates. Make sure yours is the only one for Pro Tools there and named correctly. Also check modification dates to see if it is updating. You could even pull out the default template out of the factory set which would force Eucon to always use your template (which it should anyway if it exists)
Old 03-12-2018, 09:39 AM
Thanks for pointing me in the right direction. I just needed to lock to the application. All of my soft keys came across intact btw.
MC Control touch button active window under Cubase 8 fenders74 Artist Series 1 11-07-2015 10:52 AM
D-Control: Keeping Faders on Desk whilst tracks hidden devineandrew Post - Surround - Video 1 12-03-2010 04:04 AM
Instrument track in-active, without making it in-active Ylle 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 0 12-05-2007 01:18 AM
Keeping dust out of the control surface. DraconPern ICON & C|24 4 02-19-2007 10:54 PM
what is ACtive control Fame Keyz 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 11-12-2003 01:57 PM
