Old 02-11-2011, 10:26 AM
ProTooler ProTooler is offline
Default Adding another 888/24 and Accel card. Please advise.
I searched and can't find an answer to my question. Here' 'tis:
I've just purchased a used accel card. I'm looking forward to having more processing power! :)
Anyway, I'm wanting to get another used 888/24 to add more inputs and outputs, hardware inserts, etc. Right now, I have 2 888/24's in the legacy port of my 192 i/0. Can I hook up another 888/24 to this system? If not, what's the most economical route to go?
As you can see from my signature below, I'm still in the dark ages with PT 7.1, but it's working well (knock on wood), and I can't afford to upgrade at this time.
Thanks to anyone who will offer their advice.
Have a great day.....
Bill
Mac Mini (2019)
3.2 Ghz - 6 Core i7
Mojave with 64 GB RAM
PT Ultimate (2019.10)
Motu 16a
C/24 Control Surface
Old 02-11-2011, 01:53 PM
soundboy35 soundboy35 is offline
Default Re: Adding another 888/24 and Accel card. Please advise.
I assume you have the old Y cable in the 192 legacy port to do this? I thought I heard only one legacy port can be used, but don't know for sure.
MacBook Pro 15in, 2.3gHz,i7
PT 2021.x
PT12.8.x
Old 02-11-2011, 02:05 PM
Craig F Craig F is offline
you need a HD interface (96/192/192D) to run a 3rd 888 in your system
Thank you,
Craig
Old 02-11-2011, 04:03 PM
Thanks Craig. I was afraid of that...
I'll go looking for a 96.
Thanks so much for your help.
Yes Soundboy, I have a y cable running the two 888 24's.
Bill
Mac Mini (2019)
3.2 Ghz - 6 Core i7
Motu 16a
Old 02-13-2011, 03:12 AM
JFreak's Avatar
JFreak JFreak is offline
Yep. You will always have to connect a HD interface to a HD card first, and then you can connect legacy MIX hardware to the legacy port of the HD interface.
so if you have lots of old gear...
HD1 = 32 tracks = 16trk HD interface plus 16trk MIX interface
HD2 = 64 tracks = 32trk HD interface plus 32trk MIX interface
HD3 = 96 tracks = 48trk HD interface plus 48trk MIX interface
... and so on.
Janne
Old 02-15-2011, 05:14 AM
Thanks J!
So if I understand correctly, I just have to get an HD i/o, then I can add another 888/24 (or 2) if I want?
Thanks so much everyone for your help...
Bill
Mac Mini (2019)
3.2 Ghz - 6 Core i7
Motu 16a
Old 02-15-2011, 07:20 AM
WernerF WernerF is offline
Does an HD io work with a PPC Mac and P Tools 7.1?
Old 02-15-2011, 07:34 AM
Yes, I have a 192 now, and from that, I use a "Y" cable which connects to two 888/24's, all playing well together on a PPC Mac (Dual 2.0). :)
Bill
Mac Mini (2019)
3.2 Ghz - 6 Core i7
Motu 16a
Old 02-15-2011, 11:20 AM
JFreak's Avatar
Originally Posted by ProTooler View Post
Thanks J!
Yes! Every HD interface is able to carry 16 tracks of compatible MIX and all you need to know is one HD card means 32 tracks of audio, whether 32 tracks of HD or 16HD+16MIX.
...and that is the cheapest 48k 8-trk AES interface money can buy! AFAIK, the non-24-bit 888 interfaces should also work with the HD legacy port so if you only need 48k AES it's dirt cheap. Check eBay and you can grab a real bargain.
Janne
Old 02-15-2011, 11:47 AM
I meant the new HD io as opposed to the old 192 io.
Adding another Accel card ? jackp Pro Tools TDM Systems (Mac) 8 10-28-2012 09:25 PM
Adding an Accel Card Drama Diggerthedogboy Pro Tools TDM Systems (Win) 2 11-11-2011 11:26 PM
Adding another Accel card Dusan Pro Tools TDM Systems (Win) 4 02-18-2010 04:05 PM
adding an accel card to an HD3 system Brad Ryan Pro Tools TDM Systems (Mac) 2 09-13-2005 02:57 PM
Adding Accel Card to HD3 -Questions Ed Kish Pro Tools TDM Systems (Mac) 6 11-18-2003 01:43 PM
