I was just playing w/ Signal Generator and noticed the RMS/Peek buttons
Well they are backwards, I get a about 2-3 dB more when selection RMS than when I select Peek on my external meters settings are 1000 Hz at -20 dBFS.
... "Fly High Freeee click psst tic tic tic click Bird Yeah!" - dave911 Thank you, Craig |
![]() Quote:
If the peak level setting in Sig Gen for a sine wave is -10 dB, PT will measure it (peak) as -10 dB. So far so good. If the rms level setting in Sig Gen for a sine wave is -10 dB, PT should measure it (peak) at -6.98 dB. That’s correct behavior. (If you’re in peak, and you switch to rms in Sig Gen, the level should go up by 3.02 dB. If the peak measurement of a sine wave is at, say, -10 dB, the rms measurement of that same sine wave would be at -13.02 dB (3.02 dB down). However, if you set the rms level in Sig Gen to be the same as the peak level (-10 dB), then the peak measurement of that rms sine wave in PT should be 3.02 dB hotter (hence -6.98 dB). GO here if you want to learn more about RMS (Root Means Square) : http://www.tpub.com/neets/book2/1f.htm -tv
Tim vdB Avid Audio "There's a fine line between stupid and clever." |
Is Signal Generator gone?! | nz | Pro Tools 9 | 1 | 12-27-2010 07:39 AM |
Signal Generator? | Major Matt | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 7 | 03-20-2007 11:53 AM |
Use of a signal generator | reverieman | Pro Tools TDM Systems (Win) | 1 | 10-25-2006 06:59 AM |
Signal Generator in 6.1 | Clash310 | Pro Tools TDM Systems (Mac) | 2 | 08-29-2003 04:54 AM |
signal generator for what use? | jinsel | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 2 | 03-11-2002 03:01 PM |
