Old 07-28-2006, 12:49 PM
Cavet Your Eruptor Cavet Your Eruptor is offline
Default Signal Path (for an 001)
I have been using my 001 as my mic-pre since I got it, but I have been thinking of adding an aftermarket model as an upgrade.
I was just curious how everyone routes the output from the mic-pre to their Digi equipment - whether 001, 002, mBox or whatever. It seems to me that I wouldn't want to use the 001's pre's for input if I had a separate unit.
Should be an easy one to answer - but thanks in advance anyway!
CYE [img]/images/graemlins/smile.gif[/img]
www.cavetyoureruptor.com
Old 07-28-2006, 12:53 PM
spkguitar's Avatar
Default Re: Signal Path (for an 001)
The 001 has 2 preamps and 8 line level inputs. Third party preamps (typically) output line level signals. You would connect the line level outputs of the third party preamps to the line level inputs of the 001.
Old 07-28-2006, 12:55 PM
spkguitar's Avatar
Then, of course, there are the 8 channel lightpipe inputs, and the two channel S/PDIF ...
plugins and signal path joe_04_04 Pro Tools M-Powered (Mac) 9 03-21-2010 02:14 PM
Signal Path bluesna Tips & Tricks 0 01-10-2005 01:02 AM
signal path plug-in nightshade crisis 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 10-09-2002 11:31 PM
Ideal Signal Path xterling 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 17 05-16-2002 01:43 PM
C 24 signal path (does this look right?) sidereal ProControl, Control|24, Command|8 3 03-19-2001 01:12 AM
