Hi all.
I plan to do a clean install of Windows 7 Professional 64 bits. My system is a bit outdated but still a workhorse: Intel Core 2 Quad Q6600 2.4 GHz Asus P5Q3 Motherboard 8 GB DDR3 PC1333 Ram is there any recomendation for the clean install? maybe something I should tweak in the BIOS? Any advise will be greatly appreciated Thanks Ed. |
Before you do anything, are you in the middle of any projects? If so, finish the project first!!!
If your old setup is working well, I would image the system drive before you wipe it, or pull it and start with a fresh drive(its nice if you can slap in the old drive and get work done if anything goes sour with the upgrade). Re. the BIOS, the 2 things I would check are RAM timing/voltage(if you used the AUTO setting, try manual and set for the exact timings and voltage for your RAM) and make sure your drives are set to AHCI and not IDE(AHCI allows for hot-swapping SATA drives). I have all my drives in a Kingston drive cage(4 slot) so I can swap recording drives in seconds(eject a drive, pull it, slide in the next drive and count to 10....ready to use). Of course, you need to close and reopen Pro Tools so it sees the drive change ![]() ![]()
Gigabyte X79/intel i7 3930K, 32GB RAM, HD/Native, 192 IO https://www.facebook.com/search/top/...0sound%20works The better I drink, the more I mix ![]() BTW, my name is Dave, but most people call me.........................Dave |
Pro Tools and Win7 64 Bits | lemec | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 2 | 06-05-2012 04:46 PM |
Help¡¡¡ I/O 888 and I/O 882 20 bits | alejandrovalido | General Discussion | 3 | 04-26-2011 01:19 PM |
Timecode Bits...Moving files from other DAW's to Protools | TCLguy1 | Pro Tools TDM Systems (Mac) | 4 | 02-09-2010 02:06 PM |
bits & khz | draven | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 33 | 07-26-2003 12:13 AM |
BASICS - 16 bits vs. 24 bits ? | thermoboy | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 27 | 02-15-2002 11:57 AM |
