Old 03-26-2025, 05:06 AM
Mr.O Mr.O is offline
Default Wavelab Pro with Protools HDX
Is anybody using Wavelab Pro with Protols HDX hardware on OSX? Any success with the "External FX" Plugin in Wavelab? My setup is OSX Ventura, Protools HDX 2024.10.2 and the Input on the "Insert FX" plug in doesnßt get a signal. Analog Patchbay ist checked and works.
Old 03-26-2025, 06:32 AM
tope d's Avatar
tope d tope d is offline
Default Re: Wavelab Pro with Protools HDX
Hi. Have you already setup External FX in the Audio Connections?
From what I saw, In the Master Section or Inspector, you’ll need to add the External FX plug-in to the effects list.
In the External FX window, open the Audio Bus menu and select the bus that you have set up in the Audio Connections.
In the Latency section, click Detect to measure the latency of the audio signal.
Latency is the time it takes for the audio signal from WaveLab Pro, through the external effect device, and back to WaveLab Pro. WaveLab Pro automatically adapts to the latency.
Use the Send Gain and Return Gain faders to adjust the gain of the outgoing and incoming audio.
Can you share a screenshot or screen recording of your workflow?
-Tope
To create a support case with Avid Support, go to https://www.avid.com/learn-and-suppo...-music-support
www.topedomingo.com
Old 03-26-2025, 07:53 AM
Have done this exactly! The interesting thing is, that with Protools HD Native in my Studio B it works. Has somebody done this in HDX successfully?
Old 03-26-2025, 09:41 AM
First question is the CoreAudio device for your HDX interface alive and working? Shows up OK in Audio Midi setup? Including while you are trying to use it here? Nothing else trying to use it? This CoreAudio driver does not seem the most reliable thing.
Edit: and wavelab has macOS "Mic" privilege? Here it is recording audio from coreAudio inputs so needs that.
wavelab 6 sbag Tips & Tricks 1 12-21-2009 03:40 PM
wavelab essentails with protools ? jackp 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 0 10-12-2006 03:49 PM
converting wavelab to protools sassy1 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 2 08-11-2006 09:08 AM
Wavelab 4.0 jrolf 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 3 11-12-2003 09:19 PM
Protools 5.01 and WaveLab Camilo Orozco Pro Tools TDM Systems (Win) 5 10-06-2000 04:24 PM
