I been having trouble with the transport counter not moving smoothly.Not sure what is causing it ...Can you friends help me with that problem ?Thanks
Also when i pull a menu down from the top the white menus flash..Also i have activated HEAT but i can't find the button to turn it on.Do i need to download it.I think i have it for a year with my upgrade. Last edited by mikeyman; 03-24-2025 at 10:31 PM. |
SiSoftware Sandra
ID Host Name : DESKTOP-GHTFHL5 Workgroup : WORKGROUP Computer Model : OEM System Product Name Serial Number : System Ser********** Chassis : OEM Desktop Mainboard : ASUS PRIME Z370-A Serial Number : 1803224******** BIOS : AMI (OEM) 0809 06/22/2018 Intel Management Engine (ME) : 11.8.50.3470 System Memory Total Memory : 16GB DIMM DDR4 Processors Processor : Intel(R) Core(TM) i7-8700K CPU @ 3.70GHz (6C 12T 4.3GHz, 4GHz/4.4GHz IMC, 6x 256kB L2, 12MB L3) Socket/Slot : FC LGA1151 Chipset Memory Controller : ASUS PRIME H310M-D 100MHz, 2x 8GB DIMM DDR4 2.4GHz 128-bit Memory Module(s) Memory Module : Crucial/Micron BLS4G4D240FSB8FBD 4GB DIMM DDR4 1Rx8 PC4-19200U DDR4-3002 XMP (16-16-16-38 4-54-18-3) Memory Module : Crucial/Micron BLS4G4D240FSB8FBD 4GB DIMM DDR4 1Rx8 PC4-19200U DDR4-3002 XMP (16-16-16-38 4-54-18-3) Memory Module : Crucial/Micron BLS4G4D240FSB8FBD 4GB DIMM DDR4 1Rx8 PC4-19200U DDR4-3002 XMP (16-16-16-38 4-54-18-3) Memory Module : Crucial/Micron BLS4G4D240FSB8FBD 4GB DIMM DDR4 1Rx8 PC4-19200U DDR4-3002 XMP (16-16-16-38 4-54-18-3) Video System Monitor/Panel : LG HDR WQHD (3840x1600, 37.5") Video Adapter : NVIDIA GeForce GT 1030 (384S 3C SM5.2 1.23GHz/1.47GHz, 512kB L2, 2GB 6GHz/6GHz 64-bit, PCIe 3.0 x4) Graphics Processor CUDA : NVIDIA GeForce GT 1030 (384S 3C SM6.1 1.23GHz/1.47GHz, 512kB L2, 2GB 6GHz/6GHz 64-bit) OpenCL : NVIDIA GeForce GT 1030 (384S 3C SM3.0 1.23GHz/1.47GHz, 512kB L2, 2GB 6GHz/6GHz 64-bit) D3D 11 : NVIDIA GeForce GT 1030 (384S 3C SM11.5 1.23GHz/1.47GHz, 512kB L2, 2GB 6GHz/6GHz 64-bit) OpenGL : NVIDIA GeForce GT 1030/PCIe/SSE2 (384S 3C SM4.60 1.23GHz/1.47GHz, 512kB L2, 2GB 6GHz/6GHz 64-bit) Storage Devices Disk : Samsung SSD 860 EVO 250GB (250GB, SATA600, 2.5", SSD, SED) Disk : WDC WD1003FZEX-00K3CA0 (1TB, SATA600, 3.5", 7200rpm) Disk : Seagate ST2000DL004 HD204UI (2TB, USB3/SATA300, 3.5", 5400rpm, 32MB Cache) Disk : SanDisk Cruzer Glide (15.7GB, USB2) Optical : ASUS DRW-24B1ST j (SATA150, DVD+-RW, CD-RW) Logical Storage Devices System Reserved : 500MB (NTFS, 4kB) @ Samsung SSD 860 EVO 250GB (250GB, SATA600, 2.5", SSD, SED) Audio (E:) : 932GB (NTFS, 4kB) @ WDC WD1003FZEX-00K3CA0 (1TB, SATA600, 3.5", 7200rpm) IOsafe (G:) : 100MB (NTFS, 4kB) @ Seagate ST2000DL004 HD204UI (2TB, USB3/SATA300, 3.5", 5400rpm, 32MB Cache) Removable Drive (F:) : 15GB (FAT32, 16kB) @ SanDisk Cruzer Glide (15.7GB, USB2) Hard Disk (C:) : 232GB (NTFS, 4kB) @ Samsung SSD 860 EVO 250GB (250GB, SATA600, 2.5", SSD, SED) Hard Disk : 552MB (NTFS, 4kB) @ Samsung SSD 860 EVO 250GB (250GB, SATA600, 2.5", SSD, SED) Optical Drive (D:) : N/A @ ASUS DRW-24B1ST j (SATA150, DVD+-RW, CD-RW) Storage System Storage Pool : Primordial (3TB) Peripherals LPC Hub Controller : ASUS Z370 (Union Point) LPC/eSPI Controller Audio Device : ASUS ICH200 (Union Point) HD Audio Audio Codec : Realtek Semi 1168 Audio Device : Gigabyte GP108 High Definition Audio Controller Audio Codec : nVidia 0081 Disk Controller : ASUS ICH200 (Union Point) SATA controller [AHCI mode] Disk Controller : ASUS ICH200 (Union Point) PMC USB Controller : ASUS ICH200 (Union Point) USB 3.0 xHCI Controller USB Controller : ASUS ASM2142 USB 3.1 Host Controller SMBus/i2c Controller : Intel ICH SMBus Printers and Faxes Printer : Microsoft Software Printer Driver (300x300, Colour) Printer : Microsoft XPS Document Writer v4 (600x600, Colour) Printer : Microsoft Print To PDF (600x600, Colour) Fax : Microsoft Shared Fax Driver (200x200) Biometrics Voice : Analog NUI Voice Virtual Sensor (Voice) Peripherals Media Player : ST2000DL 004 HD204UI (100MB) Media Player : SanDisk Cruzer Glide (14.58GB) Network Services Network Adapter : Intel(R) Ethernet Connection (2) I219-V (Ethernet, 1Gbps) Network Adapter : TP-Link Gigabit PCI Express Adapter (Ethernet, 100Mbps) Operating System Windows System : Microsoft Windows 10 Personal 10.0.19045 Platform Compliance : x64 Performance Enhancing Tips Warning 2513 : TPM not detected. Some security features are unavailable. Tip 3 : Double-click tip or press Enter while a tip is selected for more information about the tip. |
i am running PT's 2024 10.2 on windows
I have done the optimizations and the only one that PT's would not run on one tweak so i just couldn't do it..I will go thru them again Last edited by mikeyman; 03-25-2025 at 09:43 AM. |
A few things that hit me:
1-I am not familiar with that motherboard/chipset so I don't know if that might be a compatibility issue or not 2-make sure there is no disk in the optical drive 3-With System Usage meter showing, how high is it hitting on the top bar? If its near or at the red, then the system is working too hard(this requires lots of troubleshooting to find out why). If not, then no issue for #3. 4-Do you have Hyperthreading on or off? Test the other way to see if performance gets better or worse(it really is different from one PC to the next on this setting, done in BIOS/UFEI and is often worth checking) 5-Maybe update the graphics driver? 6-what is this drive doing: Disk : Seagate ST2000DL004 HD204UI (2TB, USB3/SATA300, 3.5", 5400rpm, 32MB Cache) I ask because its too slow for recording or sample libraries(okay for backups). How big is the session giving you trouble(and is it that session or any session)? How many VI plugins? Ozone? As for HEAT, your VIEW setting menu should give an option for HEAT controls on each AUDIO track(it only works on AUDIO tracks). The master HEAT controls are found by hitting the tiny side arrow at the lower right corner of the MIX window(similar to the arrow that opens the Tracks/Groups lists on the left side.
HP Z4 workstation, Mbox Studio https://www.facebook.com/search/top/...0sound%20works The better I drink, the more I mix ![]() BTW, my name is Dave, but most people call me.........................Dave |
![]() Quote:
![]() Quote:
how can i check to see what drive PT's is recording to?
Yes, go through the AVID Optimizations again. Also, go through all the AVID Troubleshooting steps.
Desktop build: Pro Tools Studio 2024.6 / Win 11 / i9-11900K @ 5.1GHz / 64GB / 4TB NVMe PCIe 4 / Gigabyte Z590 Vision D / PreSonus 2626 Laptop: Pro Tools Studio 2024.6 / Win 11 / i5-12500H / 16GB / 1TB NVMe / Lenovo IdeaPad 5i Pro / U-PHORIA UMC1820 Ancient/Legacy (still works!): Pro Tools 5 & 6 / OS9 & OSX / Mac G4 / DIGI 001 Click for audio/video demo Click for resume |
Setup menu, Disk Allocation
![]() Quote:
ok yes i will there is a lot of stuff there.Thanks |
Odd counter/transport behavior | TheHopiWay | Pro Tools TDM Systems (Mac) | 0 | 02-20-2010 08:30 AM |
transport/counter/clock behaving strangely | hydrophilos | Pro Tools TDM Systems (Mac) | 1 | 08-03-2009 05:59 PM |
AMDX2 Jerky meter and counter behaviour solved! | Dr Dave | Pro Tools M-Powered (Win) | 3 | 02-19-2006 04:37 PM |
Problem with Transport counter jitters | DrC:drive | Pro Tools TDM Systems (Mac) | 2 | 04-22-2002 04:46 PM |
HELP! Jerky Meters, Counter, and Scrolling | evanbrubaker | Pro Tools TDM Systems (Mac) | 7 | 08-10-2001 03:51 PM |
